Questions Help about 2007 Tahoe Instrument Cluster / Key Fobs
Hi all, new to the forum, not new to these trucks. I've owned a 2003 Yukon, 2005 Yukon and currently a 2007 Tahoe LTZ.
Long story on my instrument cluster debacle. Ran into the blank DIC problem. Tried to get it fixed locally. Kid couldn't repair it. Sold me another instrument cluster which, after installing it, the oil % and tire pressure functions did not work. I was supposed to go back and have them replace it again either with a used one they sourced or a new OEM cluster purchased by me but that never happened.
Couple of months ago I bought two new key Escalade key FOBs off ebay. Went to program them into the Tahoe and I could NOT find the menu item necessary to do it with the current "replacement" cluster. I used some steps I found on the internet. Honestly not sure if they were the correct ones so first:
Can anyone point me to the correct procedure to program new key FOBs for a 2007 Tahoe?
That said, I also want to replace the cluster. I am about to put a Dashskin dashcap on my cracked dash and I would like to get the cluster back to full OEM functionality before I do it. I want to ensure the oil %, tire pressure, and capability to re-program new key fobs all work.
Given that, what year model instrument clusters can I use? I did do some searching and I think I found that I "should" be able to install any cluster from 2007 to 2010 and still have the capability to re-program key FOBs through the DIC.
Also, since I have an LTZ does it matter what model truck the replacement cluster comes out of? Were there features in the DIC that were unique to only the LTZ model or will any cluster work?
I saw the thread for putting Escalade clusters in other trucks. Is that something I should consider rather than just an OEM used cluster replacement?
Thanks everyone!!!
thefirebirdman
Update:
Think I finally found the key FOB programming steps here on the Forum.
After posting I went to a local yard here in San Antonio during lunch and bought a used cluster. Swapped it in onsite to test it before I bought it.
Good news: The option to re-learn new remotes was available so mission accomplished there.
Bad news: With the new used cluster plugged in I am still not getting oil life percentage or tire pressure information.
This to me seems to indicate the oil life percentage and tire pressure problem is not directly related to the cluster itself since I now have two clusters that won't show that information. Now i only ran the truck with the new used cluster for about 10 minutes then swapped my old one back in to drive it back home.
Any thoughts on why these two DIC features are not working? They worked "Before" the kid hosed up my original trying to repair it. Other than somehow damaging the connector (which I will inspect more closely later this afternoon) I can't imagine anything else the kid could have done to affect those two functions.
Also, just a side note. Comparing the two clusters the original used replacement had the option to "Re-learn tire position" whereas that menu item seems to have been replaced with the "Re-learn new remotes" option in the new used cluster. Is this as simple as the new used one is 2007-2010 and the other is 2011+? Only thing I could think of...
thefirebirdman
Hey all, may be this is just not a common problem (would be a first on this truck) but I wanted to post a couple of pics of what I see on both clusters. If anyone has any thoughts or recommendations on what could be causing this, please let me know. I really assumed this problem was isolated to the older "replacement" cluster I've had in the truck for a few years now. I was not expecting this new "used" cluster to exhibit the same problem.
Also reading other posts I realize I may not have posted much information on the truck itself yet. Its a 2007 Tahoe LTZ with the 5.3l Flex V8. Highly optioned. No real modifications other than some exhaust work to install a nicer muffler for better sound and more airflow. Not a cat-back system, no headers. I recently had to have the transmission rebuilt. I'm in a local car club here in my area and I went through a guy in the club first. He attempted to rebuild the trans but it had more problems after and he attempted to diagnose those as well but ultimately I had to take it to a trans shop. One if his recommendations was to replace the ECM. That was $175 wasted as it did not help with the trans shifting problems at all. So the ECM has been swapped out with an ebay unit re-programmed with my VIN, BUT, I need to mention this issue with the gauges existed for years before the ECM was changed so I dont think that has any bearing. I have never replaced the oil sending unit but the gauges worked fine before the cluster swap. I am also running stock tire size (all 4 are new within a year) on aftermarket 20" rims but those rims were also installed long before the cluster was replaced and all the TPMS sensors worked fine (with the aftermarket rims) before the cluster swap.
thefirebirdman
So update. Turns out the TPMS was just on me. All I needed to do was go through the re-learn procedure <smacks forehead>. Don't know why I never considered that before but glad I got it working again. So with the new "used" cluster that has the option back again to learn new remotes and the TPMS sensors now working I just have to figure out why the oil lifetime percentage is not working.
There are likely dozens of these articles but this is the one I used to have the truck "re-learn" the tpms sensors:
Geotrash
Dave
Richmond, VA
Thanks for following up with the solution! Sorry I couldn't be more help to you when you were looking for answers.
Didn't see these earlier posts. If my memory serves, a cluster has to be programmed via ACDelco's TDS system with a Tech-2 or equivalent.
St. Louis
Did you try resetting the oil life monitor by holding down the bottom button for a few seconds? Maybe like the TPMS it just needs to be reset
thefirebirdman
I did. I wish it were that easy. I think @swathdiver may be right. Its not that it needs to be reset from something <10% back to 100% which is the normal reset , its not taking a reading at all. So its possible something has to be re-programmed. I'm having the new "used" cluster repaired later today and will then take the truck to the dealership.
Unless anyone in the San Antonio area has a Tech-2? Guess I need to go read that thread.
thefirebirdman
By the way, also wanted to post these pics with more information on the different options seen on the different clusters. Would sure like to better understand when/where these options come into play.
Current used cluster: P/N 15944011 (1st pic with option to re-learn tire positions)
New use cluster: P/N 25861675 (2nd pic with option to re-learn new remotes)
Both options are in the same menu slot.
There is a thread on this forum of where guys live who have a Tech-2. DIC menu options can also change when GM Accessories are programmed into the vehicle such as the Tilt and Shock Sensors or 2-Way Advanced Remote Start.
thefirebirdman
I assume said options are programmed into the ECM? If so, since the ECM hasn't changed in my truck it still makes me wonder why different clusters have different options. Is there programming that has to occur that is specific to the clusters themselves?
Yes, the clusters and BCM and others too possibly. It's an integrated system. Then you also have year to year differences such as the 2007-2010 or so trucks could initiate a tire relearn through the DIC and lose air pressure while later models must use those $10 wands.
The cluster needs to be programmed to your VIN with a tech2 in the same way the driver door switch module does, so the modules as in cluster or switches are aware of the vehicle's options. That's the reason if you were to swap in an Escalade cluster (which is a lot of work in order to make it look right) you would end up with a couple DIC messages regarding options your vehicle doesn't have- because the programming won't accept that cluster for your VIN so you can't program options, only mileage which is done without a VIN, out of the vehicle.
thefirebirdman
Is there any way to verify when a cluster has been programmed for a specific VIN or is it only reflected in the options available. I took the cluster to a local shop who repaired the solder joints for the MOSFET that goes bad due to said bad solder joints and he re-programmed the mileage for me but the guy swore up and down there was no "VIN Specific" configuration required for the cluster. So I'm wondering how do I even know if I need it? I've been driving around with the new "used" cluster a couple of days now and all seems fine. If this is something you guys think I really need to do, I may need to see if a forum member with a Tech 2 will volunteer to do it (or do it for a fee, not sure how that works). No one here local where I am has a clue. Looks like we have forum members in Houston and Dallas that have Tech 2s so I could reach out to them. Thoughts?
AFAIK there is no way to know what VIN a module is programmed to. I believe what happens when one is programmed is the VIN is simply used to look up which options are on the vehicle and that information is used to set the same options in the module. I know for instance if you remove a module like a driver door switch module from one vehicle and put it into another vehicle, it doesn't stop working. It just assumes the new vehicle has the same options and acts accordingly. So if your cluster is working correctly, you shouldn't need to be concerned. It doesn't store the actual VIN, just the options that vehicle had. Hope that makes sense.
thefirebirdman
It does!! Thanks for all the help on this. Other than getting the oil life % working (which I am hoping is also a re-learn procedure), I think I'm good to go with this new cluster. Only took me 5 years to get it addressed lol. Dash and other goodies are on the way. I think my new key FOBs from Boost Auto are supposed to show up today.
thefirebirdman
Final Update (I hope). With a new dash sitting in the garage waiting to be installed I took the Tahoe down to my local Chevy Dealer here to look at the Oil Life Percentage issue in the (new-to-me) used cluster I installed. The last hurdle to getting back to the normal OEM cluster with OEM functions I had six years ago BEFORE I took it in for a "cluster repair".
According to the Dealer, the percentage is not working because I installed a "salvage yard" cluster (they weren't wrong lol) and it now needed to be re-coded for my truck. So 1 point for @Rocket Man and 0 points for the local "Cluster Repair" guy who said nothing else needed to be coded to the cluster except the mileage. Note to others here: There are hundreds of places to get a cluster "repaired" but take it from me, most probably only know how to fix the solder joint and/or replace the bad diode and update your mileage, that's it. If you swapped clusters (or now have to swap clusters due to a "failed" repair) they are NOT going to know how to address the other issues I listed below. The Dealer charged me too much for this coding service ~$250 but it works again and FINALLY, 6 years later I have a 100% functioning cluster again WITH the DIC repair.
So word of advice to other owners. If you run into the problem with the DIC display, if all they do is repair the solder joint for the diode in question or replace the diode on your original cluster and re-install you will probably be just fine. If however, there is any problem with your cluster or they "mis-handle" the repair and you have to install a used one from a salvage yard etc... please keep these things in mind:
1) Depending on the cluster you get, it may be "coded" for different options as seen in this thread. In my original cluster I had the option to re-learn new keyless entry remotes but not the option to re-learn the TPMS sensors. The used cluster the original "repair" shop sold me had the opposite. It had the option to re-learn TPMS but not re-learn new remotes. In my opinion this was a problem because there is a way to re-learn the TPMS sensors without using the DIC at all. I am not aware of a method to re-learn new remotes without using the DIC. If someone else has a verified way of doing it, feel free to post the steps here.
2) If you change the instrument cluster, more than likely you will have at least these three problems, maybe others:
1. Your mileage will be incorrect (obvious, but worth listing), this can be fixed but requires the right tool to change it. As mentioned above this is about the only thing the "repair" shops can do.
2. You will likely need to go through the process to have the ECM re-learn the TPMS settings. I posted a link above to do this manually, yourself.
3. You will likely need a dealer to re-code your instrument cluster to restore the functionality of the Oil Life Percentage feature which I find to be useful since its not just strictly a measure of how long its been or how many miles you've travelled but takes several factors into account. This may also be something someone can do with a Tech II but I have not confirmed that.
If there are other "issues" other owners have run into swapping clusters, please feel free to list them here but keep in mind this thread was meant more to document my challenges just swapping from one OEM cluster to another. There are other threads for other types of custom cluster swaps.
Wait…I only get 1 point? :hmmm2:
Drewphil
