Bigkevschopshop
Northside H-Town
TollKeeper
Brighton, CO
Lol, it’s supposed to say M A X I fuse. Going to drop a 200a in there now
Censorship is certainly getting liberal.. Cant even say M@xi fuse without being censored..
Waiting for it to include man, woman, she, he, him, her.. And it will automatically replace it with it, they, them... :doublepuke::banghead:
SRQYukon
Sarasota, FL
Today, I finally got around to a major suspension, brake upgrade, and differential swap (with the help of my son-in-law and another of his mechanics. In spite of major problems with the rearend sent to us by ATK (under a warranty claim), we accomplished a crazy amount of work in about 10 hours (thanks to a rear auto shop with lifts). Here's what we did:
Front of truck:
New UCA and LCA
All ball joints. tie rod ends. pitman and idler arms
Reman. steer gearbox
4-piston 2020 brake upgrade w/R1 Concept drilled and slotted rotors
R1 Concepts Optimum OEp brake pads
New SS brake lines
Atomic Fabrication Products Coilover kit with Viking coilovers
Rear of truck:
ATK rear unit swap
Bilstein 4600s
SS brake lines
Airlift coil bags and compressor
New R1 Concepts drilled and slotted rotors
New stock calipers and ceramic pads
So far it drives like a dream I once had. I'll be breaking in the rear diff. for a few days, so won't be able to do much performance testing. I'll post brake a performance review in the 2000-2006 section "4-Piston Big Brake Upgrade" section.
blueinkd
Front of truck:
New UCA and LCA
New SS brake lines
Rear of truck:
ATK rear unit swap
Bilstein 4600s
SS brake lines
View attachment 347041View attachment 347042View attachment 347043View attachment 347044View attachment 347045
Wow. Impressive. I’m jealous of the coil over setup!!! If you don’t mind what did that cost you?? I have an itch for it. I really need to get off my butt and install my Moog upper and lower LCAs. My 2020 4 piston calipers are also collecting dust in the same corner of garage
blueinkd
Front of truck:
New UCA and LCA
New SS brake lines
Rear of truck:
ATK rear unit swap
Bilstein 4600s
SS brake lines
love the blue on the calipers. What kind of prep if any did you do on them??? Maybe that will motivate me to install mine. Show some pics of the whole rig as well, lets see what they look like behind the wheels.
treehan77
TYF Fiend
Crestview, FL
Ran across a same color hood. My buddy’s was a chalkboard. $50 and took the buffer to it; not perfect, but at least it’s shiny.Fixed his window regulator, tweeter and the other doors handle that broke off. How do raise the hood is front ? “New” hood is slightly lower than the fenders etc at the front.
Front of truck:
New UCA and LCA
New SS brake lines
Rear of truck:
ATK rear unit swap
Bilstein 4600s
SS brake lines
Those rear sway bar end links are really nice ;)!
Dantheman1540
Sugar Loaf Mountain
Front of truck:
New UCA and LCA
New SS brake lines
Rear of truck:
ATK rear unit swap
Bilstein 4600s
SS brake lines
Looks killer! Love seeing big jobs like this get knocked out.
So my aftermarket keyless entry lost memory, ended up disconnecting the neg battery cable to rest it. Reconnected the cable, got the keyless to work again but in the process the ac actuator went in a loop and won't stop. This is only when the ac is on, the position keeps going to face, feet, face/feet, vents. I tried disconnecting the battery again and Reconnected, but no dice. Does anyone know how to relearn with a tech2, if not I'll have to ask one of the technicians at work for some help.
you can do it with the tech2, not sure of the exact menu but it's probably under bcm/hvac/special functions
TheAutumnWind
Front of truck:
New UCA and LCA
New SS brake lines
Rear of truck:
ATK rear unit swap
Bilstein 4600s
SS brake lines
All that awesome shiny and rusty hubs!
Raise the hood latch. The holes are slotted to allow adjustment. Loosen the three bolts and slide it upward. If there's slack after adjusting (hood can be rattled up and down when latched), back out the rubber bumpers on the top of the core support a little at a time and check. Worst case, you'll have to bend the loop in the hood downward.
SRQYukon
Sarasota, FL
I took my angle grinder to the new calipers and smoothed the rough castings and took about 3/16" off the inner shoulder to be sure I had enough clearance for my 22" wheel. Glad I did that because the clearance on the driver side is only about 1/16". Anyway, after smoothing, I used a high heat primer and several coats of VHT bright blue caliper paint, and several more coats of clear caliper paint. Not a show-quality job but looks pretty cool (I'll post some pictures later this afternoon with the wheels on). I'm really tired of red calipers, so opted for something a little different.
Escalade2007
