2007 Tahoe/Weird clunking when gas is pressed
Damsinitial
Got a 2007 Chevy Tahoe with 177Xxx , When I’m driving on the highway & I let off the gas and repress it, it will make a weird clunk noise.
I’ve searched everywhere online and can’t find anything about it.
its only when I’m in drive and it only does it sometimes.
sometimes it has a delay when I press the gas and then when I end up having power.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
Where do you hear the noise? In front of you, under you or behind you? If in front, I agree with @CaptainAmerica1 and think it could be motor mounts. If under you, then may be trans mount. If behind you it could be diff gear slap or...
Can you feel it? In the steering wheel, under your butt, in the floorboard at your feet?
Do you know how to check for the engine mounts?
TollKeeper
Brighton, CO
I have a clunk in mine as well that I have been chasing. Its only when I accelerate from a stop light for me thou, mine is definitely in the rear end somewhere. Hope my control arm bushings, or whatever they are called, are good.
I never thought about that, I’ll have to check it out thank you
Your rig takes the same rear control arms, upper and lower, as @TollKeeper 06 Escalade, in post #8. If the noise is in the rear. Have not heard from you yet where the noise appears to be coming from. Secret?
Welcome to the Forum from NH.
Pics of the truck, please.
1. Slip yoke on the front of the rear drive shaft going into the transmission.
2. Motor mounts
3. Front differential support mounts (This was the cause of my clunk issue - replaced the 2 mount arms and bushings, each sold as one unit)
2010ppv03
First time I drove my 2010 Tahoe, I could swear up and down the noise was coming from the rear end. Turns out, the motor mounts need replacing. I did purchase the hummer H3 motor mounts with the solid rubber.
Easy way to check, open the hood, start the vehicle, put in drive, hold one foot on brake and hit the gas, you will see your engine move and hear the clunk at the same time. Got the motor mounts off Amazon.
GM Genuine Parts 25847739 Engine Mount https://www.amazon.com/dp/B010GPIUB...abc_GGEFKDH3B6WJ8CM6KJEV?_encoding=UTF8&psc=1
Good luck
Streborel
Absolutely motor mount.
retiredsparky
As mentioned above, the transfer case can also cause this noise. There is a large chain in the case that transfers power to the back and front differentials. That chain can wear and stretch, causing a clunking noise.
This possibility does not rule out the motor mounts.
veteran111
