ZW7 Premium Smooth Ride?
Brandon2489
Hello all. I bought my 2011 Tahoe LT with 80k on it back in 2018. At 100k I replaced the shocks and struts with new gm parts. Kept original springs. Tahoe now has 130k on it and I just don't get the hype of the Premium smooth ride. Maybe I was expecting something more. I didn't even change when I installed new parts. Is there something I'm missing? Also I hear people complaining on the price of rear shocks being upwards of 200 dollars a piece. That was not the case with mine. They were about 70 dollars for each rear and maybe 80 dollars for each front. I am pretty certain I got the correct parts for the ZW7 RPO code. Stabilizer links were also changed. Anyone have any insight? Thanks
Brandon2489
Brandon2489
The originals probably weren't quite worn out when you replaced them at 100K. Just changed mine out at 162K.
Ours rides quite nice, even with All-Terrain tires and even better when loaded as these things were designed to tow and haul weight. Put 100 pounds behind the rear axle and she'll settle down nicely.
What kind of tires and wheels is she sporting?
The $200+ dollar shocks are for the folks with Air Ride (Z55) and Magneride (Z95) suspensions.
Brandon2489
Brandon2489
Wheels are factory take offs from a 2018 model Tahoe. They are 18 inch wheels. Tires are Michelen Defender LTX M/S with 20k on them. I run them at 32 psi.
Tire size is 265/65R18
Those should provide an excellent ride unless there is a defect somewhere. What symptoms or concerns do you have with the ride? Is it just harsh, vibrations, etc.?
Brandon2489
Brandon2489
Just very harsh over larger bumps. Otherwise smooth and most pavement.
CaptainAmerica1
Arlington TX
ZW7 has the nivomat shocks in the rear and a softer spring. Do you also have the G69 rpo code? I’m betting you replaced the rears with regular shocks and didn’t upgrade the springs at the same time and that’s why it rides like crap. I did the same thing and my problems were resolved with the installation of some Z71 springs from moog.
Brandon2489
Brandon2489
The part number for the shock and struts are said to be for my vehicle according to the vin. I will double check for the G69 rpo code. I have the ZW7 RPO code indicating I should have the nivomat shocks. What is the G69 RPO code. I do not have that code
Brandon2489
Brandon2489
Here are some of the G-codes:
I believe that the last year for the Nivomat technology (G65) was 2006. I might be wrong but it wasn't too long after that.
Thanks flees. I did some more research and per my RPO codes I have the base rear springs(YD6) and base front springs(YD5) with the premium smooth ride suspension (ZW7). So the shock part number 22755311 and strut part number 20955487 that I have installed seems to be the correct parts for my application. The rear does not sag. It is actually about 2 inches taller so I don't think it's a spring sag or wrong spring problem. It rides smooth on good pavement and smaller bumps. It's harsh over relatively large potholes on the highway which I guess it probably would be. I think my biggest complaint is the premium smooth ride expression is a little miss leading. I feel like it rides more like a work truck haha. I guess if I wanted a true premium smooth ride I should look into the Cadillac variant. Overall it's not terrible just not what I was expecting. Otherwise it's the first american vehicle I have owned and it has been great. In the past I have had Honda, Toyota, Porsche and BMW. I really like the ease of working on this vehicle.
TollKeeper
Brighton, CO
Are the Nivomats G69 or G65?
I checked my build sheet, and I have Z55 and G69 but not ZW7.
I know I need shocks, but if I need Nivomats, that changes things a bit, doesn't it?
Nivomats are self-leveling, G65, which you don't have. Your G69 code indicates an air system; do you have a compressor? And I would think that your shocks would have air lines to them and rubber bladders. Nivomats have no electronic or air connections.
Got a pic of one of your shocks?
Did you replace your jounce bumpers? All of them, even the ones inside the struts?
We finished replacing our rear shocks and struts last night and the ride was noticeably improved. We also replaced the upper and lower insulators on the coils, front and rear too.
That was a GMT800 set up. No Nivomats on GMT900.
No Nivomats for you, just rear air shocks and maybe a compressor overhaul.
Brandon2489
Brandon2489
I did not replace the bump stops. I probably should have though. They seemed to be in good shape and still rubbery/soft.
Ok, did you replace the upper and lower insulators front and back? All of these things contribute to the ride being soft or harsh.
The only other thing I can think of at present is that the wheel and tire size (not the actual tires you have) was sized on our GMT900s for the Z71 off-road suspensions and do not ride as soft as say the 265-70-17s because their sidewalls are about 5/8" an inch less or so.
How about the control arm bushings and ball joints front and rear?
Brandon2489
Brandon2489
No I did not replace the insulators or the control arm bushings or ball joints. Everything seemed to be in good shape. Rubber looked good with no cracks and ball joints were tight with no slop.
Mines is an 07 I had nivomats
Well, that's a first for me. Never seen one with Nivomats. So you have RPOs ZW7 and G65?
How do you test the ball joints without a dial indicator? The failure is half to one millimeter of movement. Well, they're probably not bad or contributing to the harsh ride but I bet those other parts might be.
Where is everybody else? There's guys on here who have forgotten more about suspensions than I'll ever know.
@Bigkevschopshop @Doubeleive @gooffeyguy @91RS
Brandon2489
Brandon2489
I didn't test the ball joints with a dial indicator. And frankly I never will lol. I will say that the front end takes bumps very well just the rear tends to be more harsh. Maybe due to more weight upfront than the rear? Like I said it feels like im driving a truck more than a large SUV.
BadDaddy2003
