Bigkevschopshop
Northside H-Town
i didn't really do anything except order stuff. Yesterday I came to the realization that there's one more thing I'm not going to have somebody else do for me anymore- tuning. Or in this case reading my PCM data to see why my trans keeps going into limp mode. I'm running out of possibilities and i want to be able to manually command shifts etc so I ordered an HP Tuners MPVI2+ Pro. And also ordered an internal wiring harness kit that comes with all the internal OEM electronic components. I already replaced all 3 shift solenoids so I guess I'll have extra. Hopefully this will take care of it and I can get on with my life. And eventually learn to tune. It's been coming for awhile, I don't like relying on others. I still think Blackbear is great for the majority of people but it's time for me to move on. I have no more patience and I can't stand waiting on someone. :deal:
Totally feel the same way... I hate waiting on others, and I don't like relying on people either... Some things I don't want to do myself, and may farm out, others Id rather do it myself than have to do the waiting game...
TheAutumnWind
naughty list…
Ever have to beat your lug nuts off, because you got a screw in your tire, and needed to stick a plug in the hole? Lubricating the studs might keep you from being down on your knees all day.
So you removed an end, cut the crossbar, and reattached it? That should work.
The crossbar is too short actually. The z71 rails must be slightly closer together. But there is enough meat on the ends that I can slide each of them out ~1/2" reattach them and they would still be quite sturdy. I have not made that modification just yet. Should have tried harder to find a "escalade" set of cross bars. Doh.
TheAutumnWind
Got stopped last night, and was told I had a brake light out..
So I put some new bulbs in the back.. Thinking about going with the LED variants later.. But for now, gotta watch my budget.
I have LEDs in my turn signals and reverse lights but I had some trouble with the brake lights where my chmsl was acting up. I think you may need the srck bulbs or something for those.
Keviebear86
My OEM grill (fake chrome plated) has been slowly chipping away and the plastic chrome has been coming off. Is there a process I can use to remove all of the chrome so I can have it paint matched to the body? I have access to a sand blast cabinet, but I was a little reserved with that idea since its kind of abrasive. I have a cheap black grill in their now and it fits terribly. Any help would be great, thanks!
There is no process other than you might get lucky and be able to peel it off piece by piece. Believe me I tried everything. Your best bet is to find a paintable aftermarket one that fits better. Unless you have a Denali like me, in which case there aren't any. I bought an aftermarket chrome one and had a body shop sand the hell out of it and paint it.
Bigkevschopshop
Northside H-Town
Finally did some color match on bow tie. Painted braces flat black and cleaned radiator and condenser.
I use Rotella T1 in my old motors.. Find it at tractor supply is about the only place I can find it anymore... I know they had T6 last time I was there. Worth a look if you find a tractor supply around you.
I've never looked there, but I certainly will now! I need to go to TSC for some 2-stroke oil, anyway. I use VP full synthetic and TSC is my closest supplier. Thanks for the lead!
One of the guys on here texted me this photo after we were done with his truck today:View attachment 346058
Pretty good gas mileage eh?
For ~140 MPH, that's excellent mileage! It must be his gearing cuz he's only turning about 2K RPM? AND with the load of the oil pump making 160 psi! Have any build specs of this incredible machine?
Escalade2007
