[Solved] 2000 Yukon XL high operating temp
ryanguy426
Solved -- Mix of bad thermostat, air in the cooling system, and a leaking top radiator hose at the water pump side. Reseated the hose and tightened the clamp, replaced thermostat, bled the system for an hour, and truck hasn't gone above 214°F for 4 days as of this edit. Thanks everyone!
2000 Yukon XL 1500, 5.3
Truck loses coolant with no leak, not in oil, no white exhaust. Non Castech heads (pulled valve covers and verified). Already replaced water pump. Rad not leaking.
Truck gets to 230F sometimes, going up hill on interstate or sitting with the AC on in a drive thru or in traffic/city driving. "Hot coolant" hasn't shown on the dash yet. Scan tool verifies 232F at the most so far since I started tracking it.
Supposed to drive on a 1300mi round trip road trip mid August, this temp gauge is making me nervous though. All my other vehicles have held 210° perfect. Is this normal for these trucks?
GMT800 2005 Tahoe Z71
Navy Supporting Member
The combination of the "truck losing coolant" and the higher temp, IMO, means something is not right. Is it running hotter when the coolant is low? Does it run hot if coolant is full?
How do you know there is no coolant in the oil? How do you know there is no leak? Just because you don't see coolant on the ground? Pressure tested when warm and cold?
R
ryanguy426
It runs hot pretty much no matter what.
I also put cardboard underneath my truck when I parked it for a few days, and there was never anything but a small oil leak dripping onto it that I already have known about since I bought it.
I say there's no coolant in the oil because I have checked the oil and it's not milky, I've also changed it and didn't find any water/antifreeze in it when I caught some inside of a cup. Oil looks as fresh as it did the day I put it in there a month or two ago.
I haven't had the money to rent the pressure tester yet, I just had to replace the fuel pump. I'm doing it next week to see if it holds pressure. I was wondering if there was anything common that I could check besides what I already listed. Somebody suggested I checked their heater hoses on the firewall, but they're dry and they weren't leaking.
I drove the truck to work today, when I turned it off a small amount of antifreeze came out of the overflow bottle and into the parking lot. I never noticed that before. That's the only other thing I've noticed recently
I guess the next thing to do is wait for my money to come in and pressure test it? It runs great as if nothing is wrong otherwise. Just weird.
Exactly what I was thinking when he says it runs hot no matter the fluid level and now he sees coolant puking out of the reservoir. Then I also remember he said he replaced the water pump but did not mention the thermostat. I think what is being puked out is the coolant loss and I would also check the fan clutch for proper operation and I would also remove the top cover and check for ANY debris at any cooler in front of the condenser, the condenser itself, front and back and same on the radiator.
I used to live in the country and driving around out there has more debris floating in the air when you get around pastures and fields. Can still get crap in the city but worse in the country.
treehan77
TYF Fiend
Crestview, FL
Borrow a pressure tester from autozone, advance or something. Wry well can be ******* out coolant and burning off without it ever hitting the ground.
R
ryanguy426
So I took off my fan shroud and I sprayed out the back of the radiator with my garden hose, and the entire bottom of the radiator essentially, all of the fins are bent. Probably a quarter to a half of the fins on the bottom of the radiator are all bent. I'm assuming that's a source of my problems, but I will still report back after I can afford a pressure tester.
If it's the radiator, I read online that we can upgrade to a 34 in by just replacing the fan shroud with one from a 2500. The clutch fan can stay as is, correct? (Not jumping the gun on replacing the radiator, just curious)
You can also, maybe they are still around?, get a fin comb and straighten them. I have done it before. You also need to get in between and look at the front of the radiator and both sides of the condenser.
Is there any play at the fan clutch? Does it spin smooth? Does it spin freely when cold, like free wheeling, or close to it? When warmed up it should be harder to spin.
If fan clutch leaks you should see it and feel a film at the front center of the clutch.
R
ryanguy426
Yeah, the fan clutch is smooth and I don't see any leaks or anything on it. It's definitely harder to spin when warmed up, it doesn't spin 100% freely when it's cold... is it supposed to? Like if I spin it as fast as I can it won't go a full rotation. It's loud coming from a stop, but It quiets down above 2000 RPM. Not loud at idle. I assume this is all normal, all of my clutch fan vehicles have been like this, including my two current GMT400 trucks. Fan clutch is a Hayden 2744.
The condenser looks fine, there were some leaves and some bugs in it that I sprayed out. I don't really see any bent fins on the condenser. The radiator fins are bent on the front and back though. Wtf.
That fan clutch sounds just fine. The radiator not so much for air flow. Pics? How much area on the radiator, front and back, has bent fins?
R
ryanguy426
I'll take some pictures when it's light tomorrow. The front of the radiator isn't so bad, but the back of the radiator, if you divide the radiator into quarters horizontally (lengthwise left to right), most of the bottom quarter is essentially bent. There's a lot of large patches of bent fins in other parts of the radiator as well. Not sure how well it will show up on my camera but I will try.
Here is a poorly drawn example of what I'm talking about until I can take a picture tomorrow. The spots colored red are where a majority of the bending is on that bottom section.
I think it is a combination. The fin air flow is important and is way overlooked a lot because it is "out of sight and out of mind". While it may not be the cause, I think the thermostat is the biggest culprit, it is still something that needs addressed when found. I will take a 1-2 degree difference in temp reading any day for a little bit of work. It also helps the condenser to dissipate heat as well with a free flow of air in that area instead of air turbulence getting stopped up and finding a different path for air release thru the fins.
afpj
Like treehan77 said goto AutoZone etc and "borrow" a pressure tester. You pay a downpayment (to encourage you to return it) Will you get all your money back when you actually return it. Therefore monetary cost is zero in the end. Not sure what you mean by you cannot afford to borrow a pressure tester, unless you don't have those types of stores in your neck of the woods.
R
ryanguy426
I mean I literally don't have the money right now until I get paid...living paycheck to paycheck. Spent all my money on doing the fuel pump. Money I have to my name is $0 until I'm paid, so I'm looking at other things I can do until then like cleaning the radiator. I know they give the money back, but I have to have money to give them in the first place...
I get the money problem, we have all been there. If you have a c/c the parts store will run that and credit back just like handing you cash. Do not assume what I just said is gospel. Ask the parts guy who is helping you before you leap.
R
ryanguy426
My friend let me borrow money to get the tester.
I pumped it up to 16psi and my top radiator hose started dripping from the water pump. Reseated it and pumped back to 16psi. No drips anymore, and over the course of 30 minutes it went down from 16psi to 15psi and held. No visible leaks on the ground at this point. Inspected the other hoses, haven't found any liquid near them.
I think the thermostat and the drip repair will be a 95% fix but I would still get a clear air flow for that radiator. IMO.
schafer98
