Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
i swapped the yoke on the driveshaft to the billet sonnax one, kinda pita. busted 1 of the end caps on the u-joint...had to steal some off my old ds. cleaned up the gasket surface between the trans and t-case, uses a paper gasket that sucks. i ordered a new gasket for that and a new rear seal for the tcase, they should be here tomorrow i think.
The transmission is in, bolted the front diff back up, swapped the fuel pressure sensor that i broke the fukk off in the process. I'm going to swapped the tcase output seal and prob call it a night. Dead ass tired before i even started.
I fixed a loose positive alternator cable today...:rolleyes:
Willis12345
