Never been in an 80 but I'd imagine so. You can swap the frictions and steels out while you're in there. Just check tolerance and get it on the lower side and you'll be fine. You may have to buy a spring compressor to get some parts out. I'm really not sureto change that i mostly just need to pull the pump right?
was prob just going to have them swap all the clutches also while its out and apart
Why?Now to pull the engine back out...
Whaaa
Why?
I gotta say--you have a great attitude about it. I'd be ready to burn it to the ground.its quickly becoming a **** this engine situation
its just burning coolant/pushing pressure into the coolant system. its possible i just whiffed with the head gaskets trying to do them in the truck, no water in the oil, looks like cyl #8 is cleaner in the exhaust port than the rest.
engine is on the stand in the garage...took a break to eat some spaghetti. going to try and atleast get the heads off tonight
figured while trans is out for a bit i would just do it...it am slightly annoyed
Dammit man. Like every time you've increased power, you'll have to work through this and you'll get it squared away. You're commitment to this truck/combo/crazy ass Denali has always been excellent. Far more than I could've handled (even after the second time you pulled the engine). You'll get it sorted out and hopefully be happy with the outcome. I hate that you're having issues, I really do.its quickly becoming a **** this engine situation
