Airbag light B0081 code
tired2008tahoe
ottawa canada
I have a B0081 code, erratic signal. I cleared codes still there. Changed the sensors in the RF seat and it’s still there anyone has any suggestions on what to do in this situation?
Passenger presence system, it has a little air tube and actuator that clips on under the seat, probably need to replace that. when a passenger is present it creates air pressure and turns the passenger airbag sensor on
Right after that code, a symptom code should also be present if you have the right scan tool...
DTC Descriptors
DTC B0081 0F
Passenger Presence System Erratic
DTC B0081 3A
Passenger Presence System Incorrect Component Installed
DTC B0081 4B
Passenger Presence System Calibration Not Learned
DTC B0081 5A
Passenger Presence System Plausibility Failure
DTC B0081 39
Passenger Presence System Internal Electronic Failure
DTC B0081 71
Passenger Presence System Invalid Serial Data Received
might have a broken wire somewhere under the seat area, check the wires with a meter while wiggling them, or maybe the replacement part is no good, @Rocket Man had a bad wire for the airbag I think
T
tired2008tahoe
ottawa canada
DTC Descriptors
DTC B0081 0F
DTC B0081 3A
DTC B0081 4B
DTC B0081 5A
DTC B0081 39
DTC B0081 71
Symptom 71 do you know the fix?
1. When DTC B0081 71 sets, inspect wiring and connections for a possible loss of
communication between the SDM and PPS module. Inspect front passenger seat connector to
the PPS module and seat connector to the seat harness. Do not replace the SDM module for a
DTC B0081 71 condition.
just like I said check the wiring
my 03 had a loose (broken) wire on the harness one time, very easy fix
me51
Germany
Mine shows this code (B0081-5A) very rarely. Once you crank the engine the message and the airbag light go out. Found out there's a TSB only for modelyear 2009 vehicles saying this behavior is normal if no other codes are present: TSB 08-09-41-009A
Kcrowe79
