Tonyrodz's Tahoe Build Thread
Scottydoggs
NJ
are you driving it during these scans or just holding the gas? being under load can change things, vs revving it.
the ltft are rich, might have a vac leak or the tune was set up to be rich.
the o2's look good as far as being very active, the test for them is go wot and bank 1 and 2 sensor 1 should lock in around 930's and stay there the whole time your wot.
misfires, well ya got a cam. why tuners delete the multiple misfire code from the tune. or the cel would be flashing all day long on most larger cams.
Sorry I didn't clarify @Scottydoggs this is my work van. I was sitting still bring the revs up. This van has given me heartache from day 1!
kbuskill
NE. FL.
LTFTs are rich???
I thought positive numbers meant lean, which would indicate a possible vacuum leak.
My understanding is that the positive numbers mean that the ECU is calling for 9% more fuel (as an example). A negative reading would indicate that it was rich and the ECU was calling to reduce the fuel by -9% (as an example).
Maybe we are saying the same thing in a different way OR maybe I am mistaken. Not trying to confuse, just trying to verify my thinking is correct.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
LTFTs are rich???
Your saying the same thing. It appears to be adding fuel to compensate for unmetered air.
Scottydoggs
NJ
LTFTs are rich???
your right, i got it backwards. and lean would mean a vac leak. could also cause some misfires.
I did drive it today, but I couldn't take it through its paces unfortunately. My gf was with me and she has some serious issues with her neck and spine--plates and screws--but hopefully I'll be able to soon.
New issues with her or old? You’ve been through a bit yourself lately so I hope you weren’t both laid up at the same time?
Just a continuation of old ongoing issues for her. As for me I'm invincible!! Til I die anyway lol.
On the way home I was alone, and I took a sharp curve jumping on the pkwy. I did notice it handled alot better, but I have 265 70's so there's still a little sidewall flex. It would've handled alot better with some 22's--but I sold them--don't regret it either!
I’m wondering if the reason I keep getting the random misfire code on my Denali is the cam then. Although it didn’t do it for over a year, now it does it on occasion.
Scottydoggs
NJ
might when it gets hot. that pesky p0300 code should be deleted with a cam. the lope and chop is pretty much a misfire, sooo lol you have a blower on that truck too? might need new plugs if running copper core plugs, they only last like 12-15,000 miles. puts you back on the old school days of a tune up once a years.
Hot AF today, and Mon/Tue is gonna be hotter, so if course I cleaned my front carpet and front seats. Carpet is much better, but not what I expected. I was gonna get the oem rotors cut--@$25 a piece, but then saw these-- Screenshot_20210627-193900_Amazon Shopping.jpg
I also ordered some GM abs sensors--so I thought. Looks to be only 1.Screenshot_20210627-195111_Amazon Shopping.jpg
albac
