It’s a little tight and I’d like some more breathing room eventually... most of the HEBs are pretty nice. Did you want the factory 20s or the 22s?
I've always wanted them dope-ass 22s. I think what sprung my wood for them was you mentioning selling them and the fact that you were relatively nearby. It was probably a year ago.
It's okay, though. I've moved on with life and have decided I wanted color-matched wheels. I have the wheels, just gotta refinish them.
I can only speak for Pasadena, Deer Park, etc., but I don't think I'd be able to tolerate the roads around there with 22s.
lowh07
the 22s are fine. When I had 24s it sucked in the Spring area. I only had problems with the 24s when I hit a huge pothole in college station and got an egg in the sidewall... I kinda wish these were brushed aluminum now since I’m getting tired of dark wheels. Been entertaining the idea of putting the 20s back on
What did you do to get them to move out?
Probably rev it higher than people would like on occasion. Keep in mind this is the same lady who, on my first day moving in, decided to run her sprinkler covering half my driveway and recently cleaned Tahoe, leaving water spots for days.
Bigkevschopshop
Northside H-Town
22s in htown and surrounding areas are maximum. 24s will bend lips every month...
Im on northside of Houston, we got less potholes but more concrete expansion joints that will break shit... Hit me up next time your over this way...
Just Fishing
Can't fix stupid
Utah
I spent some time reading through the 2021 forum, helping get my motivation going to finish my hoe.
also i'm seriously holding my self back from buying those AFR heads, ready to bolt on...
it's only $2600 for the pair...
:lol2:
big thing is if i fk up with the combustion chamber work, i'm not sure i can get another head gasket this summer.
:yaoface2:
RooTBeeRthe1st
Trying my luck at a tire shop that should be less concerned about liability, hoping they'll patch it since my new tires won't be here for another 6 weeks supposedly. And 4th of July is a camping trip, and a week after that is my grandpa's b-day/yearly family reunion in NorCal.(trip will probably be roughly 1200 miles total)
I really don't want to drive all that way without a spare. So I'd rather patch this tire and run it and no I still have a good spare underneath.
That looks like a big ass hole. Maybe a plug plus a patch on the inside?
Sometime the “shady” looking guys are the good ones that get sh#t done.
And sometimes they’re just shady. I used to go to a tire store that “just gets shit done” until my weights started falling off in my driveway on a hot day. I gave them 3 chances to balance my 26’s and they failed 3 times. I don’t go there anymore. The new place takes their time and does everything right. But the shady places have their uses for sure.
RooTBeeRthe1st
Had that happen with a pepboys. Less than 1 mile, all my weights flew off.
Kee Fuller
las vegas
I have a tandem garage(1 car parks in front of the other) in my new place. So i always slighty pull in then get out to make sure I’m lined up and don’t scrape against the wall. Just a regular day and now my truck won’t shift out of park. Shifter moves but nothing.
1 tow truck doesn’t have enough room on the flatbed, so they have to bring another to pull the truck out of the garage and put the truck parallel with the street to get the truck on the bed
It’s probably just the plastic clip on the shifter cable where it connects to the trans. Did you climb under and take a look?
Kee Fuller
las vegas
I didn’t, i had to get to the airport for work. I’ll let the dealership figure it out. Kind of hope it lasts something expensive so the warranty can cover it
Trippers99hoe
SW Oklahoma
Got my replacement ecu in the mail today,It is the service tag #12633238
So does it need to be flashed to my VIN or just updated to my vin with tech2 for Anti theft?
Or just send it to WWW.LT1SWAP.COM and have him do the vin update and dod delete,then do security when i get it back?
08z71bgm
Long Island, NY
DOD disable is easy. Find someone local with HPtuners and pay for the ecm credit and disable it. 50 bucks. He can also add your vin to vats with it.
HeavyHoe03
