Feels likes wheels are going to come off
I have only two ideas of what the problem is, and I do suppose it could be the wheel bearings, but I'm thinking that's not the cause. Rather, I believe it's the carrier bearing in the front diff, or that the air ride compressor is not working. For the air ride, the fuses appear to be good, the relay is good, I removed the relay and jumped 30 and 87 to send power to the compressor, and I heard it, so the compressor is good. Running out of ideas on the air ride issue, I suppose a bad module maybe?? Also, there are NO service lights on and no codes. The compressor is brand new, replacing one that ran until it burnt up, the shocks are also brand new.
It’s possible your exhaust solenoid on the compressor isn’t working. If it can’t exhaust then it won’t turn on the compressor. You can disconnect one of the air lines at a shock and let the air out. If there’s no air then the exhaust solenoid isn’t your problem. But if there is pressure and you let the air out, start the truck afterwards and watch/ listen for the compressor to turn on and bring the rear up a bit. If it works like that then your solenoid is bad or not being commanded on. The Tech2 is the tool you really need to troubleshoot the autoride system.
You never mentioned the brand of compressor or shocks you bought but if you went the cheapest route with these then they might not be working right. But I drove my 02 Denali for months with blown air bladders on my rear shocks without knowing it, and it never felt like what you’re describing. It just bottomed out occasionally.
Shtiv
Shtiv
Seattle
Thank you! I’ll do what you said. The compressor is Dormant 949-099 compressor, got cheap shocks in the back (Arnotts in front). Might spend the money and swap the cheap ones in back with Arnotts.
Members here have been running the Dorman compressors for years with no issues. I’m not familiar with it though so maybe others here can tell us if the exhaust valve is an issue with the compressor or if it’s separate. I used Arnotts compressor and don’t remember, I just know there have been issues with the exhaust valves. But try that test before looking further.
Shtiv
Shtiv
Seattle
Lead mechanic, went deep into the vehicle suspension. Found nothing, says everything looks great. Of course he was unable to feel what i feel while driving. So confused by it all.
Shtiv
Shtiv
Seattle
There was air on both, a bigger blast of air when i i disconnected line of driver side. Turned vehicle on and still no compressor.
They’re plumbed together with a y- fitting in the air lines. It makes no sense that all the air didn’t release when you disconnected the first side. Sounds like you need a bi-directional scanner like a Tech2 so you can check things and command the compressor on and off. Have you checked all the under hood fuses? Iirc there’s 2 that are for the autoride. You could take it to a shop and have them diagnose it and then fix it yourself. A Tech2 can be had for around $300 and they’re invaluable in working on these vehicles. It would pay for itself in no time.
Shtiv
Shtiv
Seattle
I’ll check the fuses again, but looked good, so did the relay. I’ll have to find a tech2 in the area (north of Seattle).
Shtiv
Shtiv
Seattle
Shtiv
Shtiv
Seattle
Yes everything. You can switch to online programming of modules via GM's site for about $80. There are 2 versions of nano, next upgrade is wireless modem in nano, about $15 more. Depends if you have wireless close. Chinacar has been good for me.
https://www.chinacardiags.com/whole...-gds2-diagnostic-tool-wifi-version-17410.html
Ordered it and will be here tomorrow. I have watched videos on setup and how to use, any pointers for troubleshooting the suspension issue??? Thanks!
exp500
Since you asked..... Feeling funny while driving is pretty general statement, but feels like it's on ice makes me want to look at things more in depth. Since you wiggled everything front and rear like control arm and mounts, front suspension, etc. How about the axle shafts when you had them open? Like rotating a paint mixing stick in a bucket. No binding or excess play? Driveshafts removed and rotated for feel? If your truck drives better in rain, then it is more related to Alignment due to less scub in rain. Lastly, your front axle IB bearing seizing momentarily will give you that exact feeling.
Good Luck and keep us updated. We're all watching.
Shtiv
Shtiv
Seattle
Good ideas, thank you! I’m thinking it might have something to do with air ride compressor not coming on. I swapped out passenger Axel again, might do the driver side if problem persists. The “ice skating” feeling is pretty much gone at the moment, which confuses the heck out of me and of course the lead mechanic didn’t feel anything abnormal and said everything looked GREAT. ‍♂️
Shtiv
Shtiv
Seattle
View attachment 280733 View attachment 280732 Does anyone know which option to select in Tech2?? Thanks !!! 2002 Yukon Denali 6.0l
I always use the 263 NVG. It doesn’t have the option for the NVG149 which is what we have. I haven’t had any problems choosing 263 NVG. I know it’s not electronic and I know it’s not 2WD. And it’s not a 2-speed.
BadDaddy2003
