Trailer brake controller
ohio5pt3
Is there a factory option for a trailer brake controller? Anyone have a part number or link? I keep ending up with one for Silverado. 2007 tahoe lt.
Geotrash
Dave
Richmond, VA
All of the NNBS900s have the wiring for the brake controller pre-installed, as far as I know. It takes like 20 minutes to install one. As others have said, the Tekonsha P3 is the way to go. Install videos are on etrailer.com.
I installed one in my ‘07 and it works great.
petethepug
Michael
SoCal
The 2012> integrated trailer brake controls in the left kick panel of the NNBS can not be added unless it’s installed on the factory line.
However, there’s always an exception to the rule. If you have the ability graft 08 Escalade into an 09 Silverado 2500 Duramax, you can add the ITBC
https://www.dieselplace.com/threads/my-upfit-build-story.869978/
The Integrated Trailer Brake Controller (JL1) was introduced in 2009 and cannot be added without literally taking the truck apart. The wiring for an aftermarket controller is under the dash.
wsteele
I forgot that point. 20min is a pretty accurate estimate. Believe me, if I can do a clean install of an aftermarket gadget, anyone can.
petethepug
Michael
SoCal
We had the Tekonsha P3 in our 08 Denali YXL when we purchased it pre loved in ‘14. Had zero issues with it when used just once.
For some reason GM didn’t want to install the ITBC on the NNBS Escalade. Not sure if they changed their mind after 2014.
Shunto
Long I$land NY
How's this setup on long upgrades? I had a similar setup but decided i needed more Power.
brice715
