My latest Adventure, update 7/11/21
bigdog9191999
bigdog9191999
sw michigan
more gun stuffs, have a scope to get mounted on the savage i picked up around the first of the year.
bigdog9191999
bigdog9191999
sw michigan
some more toy pics just because
Remington 700 in 300rum
rock river varmint ar
my cheap ar
the collection so far.
two standard bolts
two nib
and the last one is cryptic coating bolt.
60rd drum
40rd mag
30rd mag
and i just recived 10 more pistol mags ( the 9 in the middle are 15rd and the new ones are 17rds. as i will have two that use the 15 rds one stock and one i have yet to build. ) and the new mags will fit the two other frames i have to build, as well as can be used in the to 15rd pistols.
bigdog9191999
bigdog9191999
sw michigan
also picking up the panther next weekend and have some wheels to play with to see what works the best.
as well as the sony that i have purma borrowed from my mom as she hasnt used it in several years. so i will be doing some learning.
bigdog9191999
bigdog9191999
sw michigan
actually the trailer will be closer to this one. this one has a 15' deck, 10 flat and 5 dove.
the new one will be 18' deck with 5-6' dove. the difference will be no bridge around the top, as well as the deck will be a full 8' with either removable fenders or drive over fenders. we have liked the old one for so many years and it has worked so well we decided to keep it close to the original and only make a couple small changes. the width in part to my offroad toy that will not fit inside the rails of either existing trailer once it is done. it will be an xj cherokee with half ton axles and 37'tires.
bigdog9191999
bigdog9191999
sw michigan
there is a good chance this panther will be lifted at some point and possibly much like the lifted prix, and be a quazi gambler because i can toy.
I can't wait to see how you build that trailer out. Ahhh, another build thread :D
bigdog9191999
bigdog9191999
sw michigan
i will probably just showcase it in this thread, when we get around to it.
also soon hoping to get to fixing the bike! ( will post up pics and details about that in the next couple hours)
hoping you guys are liking the odd random crap! if nothing a break from the normal mundane.
I'm digging it--something different isn't always bad. Looks like your father did a good job too.
bigdog9191999
bigdog9191999
sw michigan
ok so the bike in question is my 06 goldwing. last fall i found i was leaking coolant, after i got everything apart i found the fan had rubbed a few of the row to the point they where leaking.
bigdog9191999
bigdog9191999
sw michigan
so it is all apart since last fall as i had too much with work to fix it then, and not much good time or weather to get after it yet this spring. going to be doing steering head bearings while it is all apart. but that means that the full forks, wheel ect need to come off to get it all done.
the pricy little fix, just shy of 400.
also figured because it is a huge pain in the ass to get to the headlights and they are available to get to i got some led lights that are very good for these bikes. but at least they where cheap.lol about 120 a pair, and it takes to pair.
bigdog9191999
bigdog9191999
sw michigan
so gave dad a hand we had to redeck the ramps for the tandom trailer, and i figure that i use it enough that i should help.
bigdog9191999
bigdog9191999
sw michigan
so was getting some ice cream and spotted this, and gotta say it was pretty good.
and the growing baby.
and the goldwing is getting pretty stripped down.. have to get the rear bezel off still then off comes the wheel/forks and such.
bigdog9191999
bigdog9191999
sw michigan
so before i got the bike apart we got a call and went to get a car moved for some family, and being the trip to swap the ram for the panther and being the ramps where fixed for the tandem, as the tire on the single axle was rubbing the fender so needed to swap the truck on the trailers we got the truck off, got the car picked up and unloaded and the truck loaded back up for tomorrow (thursday). the car i belive is going to be mine for hauling it, but sounds like the motor is screwed, the right front is locked up, and is rusty as sin. so i will probably cut off the cat/s and scrap whatever isnt worth keeping.
bigdog9191999
bigdog9191999
sw michigan
alright, so it was a pretty good weekend, thursday got the truck swapped for the car. and i have to say the car is a peach! ok seriously it looks like hell as it looks like a poor metallic or chamilian paint done with rattle cans, but body wise isnt that bad at all, minimal rust, and the mechanicals should be minimal to get going. there are some pics of the trip and several of the car after.
scottd
