2010 Yukon XL Grounds
somguyss
Curious if anyone knows where all the Grounds are located? any diagrams or pictures would be great.
S
somguyss
looked at it but seems you have to have a subscription in order to use the service.
thanks for your assistance though
GMT800 2005 Tahoe Z71
Navy Supporting Member
That is the whole idea. You will have all the info you need for your rig for year to year availability to search for info like this. Information is worth money and sometimes available here for free as well as opinions. If someone here has a shop manual for your rig they can hopefully help but you are asking for ALL ground locations. Your call and hopefully can help you.
Glad you found it. I typed the name wrong and went back and corrected it now.
kbuskill
NE. FL.
@somguyss
This is from the service manual....
It is not a diagram but at least lists locations.
Hopefully it helps.
Out of curiosity, what are you trying to accomplish or what issues are you having?
S
somguyss
Yes at least it is a step in the right direction and will assist me to determine if grounds or harness is the issue.
if you don't mind where were you able to pull this info from
Thanks
kbuskill
NE. FL.
Thanks
My factory service manual PDF.
Unfortunately it is too big to post and I don't have any way to host it.
There are diagrams that correspond to those locations, as you can see it lists the page number, but there are a lot of them to try and screen shot and post here.
That is why I was asking for more info on what you are trying to accomplish or what issues you are having so I could try to narrow it down to possibly get you a picture of a diagram.
As with most things on here, the more info you provide the more answers you will probably get.
S
somguyss
I was looking for all the grounds under the hood as the engine has been pulled and put back in and want to make sure that didn't miss a ground by chance as after replacement I'm getting a P0606 DTC, basically it means that there’s an error with your power control module (PCM) thought maybe Tuner had sent me a corrupt or damaged PCM that he flashed so he sent me another and getting the same DTC with 2nd PCM and there is really no way to be getting same DTC from 2 PCM unless both bad or tune is bad or there is an issue with the Engine harness that powers up the PCM and Grounds for PCM and motor and sensor circuits
BadDaddy2003
