A question about cluster lights
gcronk3
Angier, NC
Is there a way to turn on the cluster lights without turning on daytime running light? Looking at the speedometer is hard because on the depth of the cluster.
2005 Yukon Denali
Thanks
The cluster lights turn on with the park/ marker lights or headlights. It has nothing to do with the DRL’s.
Is there away to turn them on independent of any other lights?
No. They come on as soon as the marker lights turn on, there’s no other way unless you hack into the wiring harness somehow and add a separate switch which would make no sense since all you have to do is turn on the lights with the switch that’s already there, and any added switch wouldn’t utilize the chimes so you’d probably leave them on and end up with a dead battery. Why not just turn the marker lights on?
Buford bubba
