2004 6.0 NV4500 Tahoe
randeez
south florida
much better! Every time you weld, you will improve. In 6 months, you'll look back and these remind yourself of that
if you can hold a continuous bead without burn through, you dont really have to do circles or back forth or whatever, you can just run a straight line. *if it's hot enough to not have roll under and will lay flat
The back n forth "slows" me down from just blobbing on puddles
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
No way to make the dual 3" work this low, with this axle, and not cut a ton. Even if cutting was an option look how much I'd have to remove directly under ththe body mount. No thanks.
Also look how little room there is before the axle smashes the pipes
Sam Harris
View attachment 276737 View attachment 276738
Just make yourself a couple 1/2”x8” ovals man. What’s the problem..?! [emoji1787]
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
time to ditch the frame crossmember imfo, exhaust is way more important
I'd consider a super chop, gusset the crap out of the body mounts and maybe run a crossmember further back out of the dom but. The axle will still touch the exhaust in 1" of up travel so it will still make noise and find resistance. Plus a single 12" diesel tip will look cool once I toot this thing out.
Get out the BFH! :Stupid Me:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
With the recent rain weve been having I learned 3 things.
1: Windshield wipers are stupid expensive in town (average of $25ish per blade!)
2: Rock auto has awesome Trico wipers for only $8.50ish per blade
3: Nitto 420s like to hydroplane as they age. I don't remember them being this scary when hitting puddles but this weekend I almost shat my britches when I hit a shallow puddle and it sent me toward the ditch. This will likely be the deciding factor for going to a more "All season" style tire like a Michelin LTX when these are worn more.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
theyre ok in rain....not as bad as i thought, that viscous awd tho
I don't have drive wheels traction problem, it's 100% the front end shooting in whichever direction it pleases during a mild puddle event. Could still be partially due to the jacked up alignment. WIll be getting it fixed Thursday hopefully for the final time.
That tread design actually works real good in water. Those center grooves let the water exit out the rear in a rooster tail. :happy107:
The pattern looks good but the 6/32" tread depth is sketchy at best :eek:
I'd love to see @randeez showing us how well they work in some awd tight radius wet surface donuts :thumbsup:
randeez
south florida
lol my tire guy was like, these fookin things are already on the wear bars
Oops, r2 drag radials not g2 aw my bad.
I’d rather see @randeez doing dry surface tight radius donuts like the ricers.:head3:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Back to questioning my exhaust setup, since there is no way to fit dual 3" over the axle, a single 4" is the future. With the massive Flopro taking up so much space I don't think there would be room for a merge pipe after the muffler, and I don't think the available off-the-shelf merge pipes would fit the odd offset of the Flopro outlets (See pic 1). The search for a dual 3" inlet single 4" outlet muffler led me to the Gibson 788050S (link/pic below), its 8" round, 24" body, and 30"total where the Flopro is 12x9 and same body length. My main concern would be that since it has significantly less internal volume its ability to reduce drone would be reduced, maybe the 4" outlet would be quieter than the dual 3"?
The possibility of adding a 4" resonator after the axle is a good possibility, or a pair of 3" before the muffler still possible just more difficult.
(https://www.amazon.com/Gibson-Performance-Exhaust-788050S-Stainless/dp/B008CLO6YU)
pwtr02ss
Tennessee
I don't know enough about exhaust brands/sounds to weigh in on this but it looks like you're on the right track. I have magnaflow muffler on my orange truck and their catback on my camaro. Reasoning behind both was, they were quiet....
Candielaine
