I knew that would get your attention @Tonyrodz. See any angry vaginas lately?I'm sure that's not the 1st time he's heard that before![]()
Be sure to capture it for observation. You know, like they talk about doing with the unicorns in the Hot Crazy Matrix!Not lately.....but I'm looking![]()
You know I will--for observation purposes---of courseBe sure to capture it for observation. You know, like they talk about doing with the unicorns in the Hot Crazy Matrix!
Did you watch it? Funny ass shit but true.You know I will--for observation purposes---of course![]()
I've seen it before. Funny AF!Did you watch it? Funny ass shit but true.
Can you try to squeeze that part of the exhaust flat somehow?Got the Belltech bushing control arms in as well as cutting the cam bolt slot for more adjustment. I think it's already a little better and I just maxed them out in the same direction they were maxed before. Can't believe how well the little carbide rotary files worked! I'll post a link to them tomorrow when I'm not on mobile.
Not sure I can do anything about the exhaust limited rear up travel unless I cut out this crossmember or chop the exhaust and have it redone.
Who thinks I can hack the cross member and not have the frame fold in half?
Also it looks like during normal driving the bump does touch the frame a tad which is good but that's on the side opposite of the exhaust so it probably has a little more up travel independently.
View attachment 276552 View attachment 276553 View attachment 276554 View attachment 276556 View attachment 276557
Ooooohhhhh sparkles!Got the Belltech bushing control arms in as well as cutting the cam bolt slot for more adjustment. I think it's already a little better and I just maxed them out in the same direction they were maxed before. Can't believe how well the little carbide rotary files worked! I'll post a link to them tomorrow when I'm not on mobile.
. I've known the exhaust had been crunched like that for a while because the PO had the truck lowered even more than I do and he raised it back up because it smashed the exhaust so bad. I just thought it had fully self clearanced already clearly, I was wrong. Ooooohhhhh sparkles!![]()
You could cut a section out and weld in a piece of 4" steel pipe, cut in half. That would retain the strength of the crossmember and give some clearance.
@pwtr02ss forgive my earlier comment I just now comprehended what you meant by notching and then reinforcing around the notch. Not completely removing the crossmember. That's a good idea, I will have to take a better look at it and see if that's doable. The issue of how to do it with the tailpipe in place still stands and my unlove for the tailpipe section in general.
Even if I redo the tail pipe section I think a notch of some sort would be beneficial to keep the over axle hump as high as possible.
Its hard to explain things sometimes. I posted, then went and found pics, ninja edit. Sorry.
Yes, its looks like tight quarters under there. Definitely looks like no fun.
Maybe you can get a small metal saw up in there and start hacking, then do some final clearance with those badass carbide bits you have
Damn Ninja! It's ok I edited like 4 times. It might be an excuse to get that little mini Milwaukee sawzaw dude, but even then I think the tailpipes have got to go. Wouldn't be that bad I could run around a couple of weeks with them chopped off and it dumped right in front of the axle until I can figure out what I want to do and get everything clearance properly. I'm fairly certain I could do the over-axle part myself if I get some time on my neighbors lift. The only thing I don't know how to do is the hangers and uh weld pretty lol.
Oh, those rotary files are seriously beasts! Within the first 3 seconds it slung metal rabidly it shot a piece into my eye and I wore goggles the rest of the time lol.
https://www.amazon.com/gp/product/B0871WMKZ9/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
