Stuck far from home. Battery light came on, now Los of power.
Shtiv
Seattle
Hi guys, for frm home and has better light came on, and alternator voltage gauge dropped to 11. At Oreillys, they say everything looks good. But can’t start car as if battery is dead, i jump car car and it starts, but no lights and nothing works. Car drives but with a loss of power. Any ideas? I need to get home. Thank you!
Shtiv
Shtiv
Seattle
Everything is good when i jump car, but once i remove portable jumper all gauges on dash go to zero and very few things work in car And car runs like crap.
tRidiot
That sure sounds like a bad alternator.... so at O'Reilly's they checked and said your alternator was charging???
Something's off there... you should be able to run off the alternator even if the battery is bad or missing.
Shtiv
Shtiv
Seattle
Thank you! We’re checking it again. I’ll hero forum updated with what we find.
Tonyv__
Bucks county PA
Definitely alternator. If the meter shows the alternator is charging. Then you need to test at the battery to make sure you’re getting the same voltage output that the alternator is giving off. If it’s not the same then you may have a broken or loose power/ground wire somewhere
Shtiv
Shtiv
Seattle
NASCAR got nothing on you. :)
Nothing like your alternator going out when you are driving through wheat fields in the middle of NOWHERE . Luckily i was able to get to an Oreillys where i then got stranded but they had ONE alternator and it happened to be the exact one i needed and the brand i wanted.
HD_LS
Yep, Alternator & Battery are the things most likely to leave you stranded. That's why I'm a big fan of dual independent alternators & batteries. Easy to do it with these trucks. https://www.dcpowerinc.com/collecti...dillac-escalade-1999-5-7l-v8-optional-124-amp
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Good job bro.
Capybarbro
