Question
Mark Minger
Hi, I am an old man trying to learn something new. I have a 1951 GMC truck body that has been welded to a running 2000 chevy Tahoe chassis. I am hooking up new heater, wipers, stereo, and I need to know where I can find the switched assesories box to tap into. The Tahoe wiring harness comes through the firewall, but it looks like a 4 foot snake with lots of wires and unplugged connectors. I have the harness all coiled and located in a protective box attached to firewall, under dash.
I bought this project that is uncompleted and I want it on the road. Thanks, for any help. I simply need to know where to tap into power on a 2000 chevy Tahoe 4x4. Mark
Tonyv__
Bucks county PA
You might be better off running your own power straight from the battery. Buy an aftermarket fuse box. Install your own fuses and relays. That way you shouldn’t run into any headache of trying to tap into the existing wire harness. Possible overload to the existing wires or shorting fuses/relays. Sometimes it’s just easier to run new wires than trying to diagnose the Frankenstein harness you may already have
Something like this
just to give you an idea. I’ve never used it before and I would research better quality product if I was you...
bigdog9191999
sw michigan
honestly a trip to the junk yard may help you a ton. you can look into the dash of a truck that has been taken apart to give you an idea on what goes where. then if you find one that you have to take apart could give as many clues.
M
Mark Minger
Something like this
rick9667
