Raptor tire on Z71 Tahoe 21
Zeee
Hello guys
Can I fit raptor tire
lt315/70r17
On my Z71 Tahoe 2021
Kpwweb
I don’t think 17s will clear the brakes—especially the fronts.
Zeee
Zeee
So what’s your opinion bro
I need the maximum tire I can fit
Big Mama
Virginia
Use the tire size calculator on tire rack to compare what you have now versus where you want to go.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
DWSmoot
Charleston, SC
Thats a 34.5" in tire, in essence a 35. Are you lifting? Aside from the potential wheel issue, I have yet to see anyone fit a 35" tire without at least a 3.5" lift and thats with some trimming.
Good luck and let us know how it turns out for sure!
Zeee
Zeee
Thank you Joseph for your help I appreciate that ♥️
Zeee
Zeee
Dwsmoot I live in KSA I have zero options here for trimming or leveling up :(
and your car looks fantastic
Thanks mate
alghanem84
Hello guys
lt315/70r17
Tires might fit just fine depending on what wheels offsetting you choose to go with, it’s better if your new 6 lugs wheels have a negative offset to make the tires sticking out the funders an inch or two to clear them 315 with tires … either way there is only one way to find out
