Bilstein 5100
Oh Kee Pah
MAINE
I have a listing in the classifieds as a "Performance Fox Leveling Kit" but it includes Bilstein rear shocks for 0-1" ride height. Don't want to seem pushy or anything, just thought it would be an option for you to look at since you've had the shipping troubles, etc. It could get you by for a while. https://www.tahoeyukonforum.com/thr...ng-kit-other-gm-oe-parts.124544/#post-1535727
I also have my 2015 Tahoe LTZ HD Towing rear coil springs (not in my for sale listing but certainly available).
I've had to deal with a ton of ordering/shipping problems on OE parts, aftermarket parts, big names and mom and pops since August. Headaches all around.
2nd the recommendation on the coil insulators. Not too expensive in the grand scheme of things.
Joker619
05047c58-c74a-4fa1-9d2b-0fad1ccfc32b-jpeg.261374
Nice Setup...I've been going back and forth with 4 inch Readylift kits and level kits but I think I'm gonna do the Bilsteins after looking at your rig. I know it's gonna be a little extra but I think it'll be well worth it...if you don't mind, I had a couple questions.
1. Ride quality with the 1 inch spacer in back...is it pretty equivalent or better than stock...could you do without the spacer in the back and still had a nice level??
2. Planning to put smaller 33s (285 65 18) w Bilsteins to highest setting. Do I need new upper control arms?? Or am I cool with stocks. Planning to run my stock Rims.
Thanks in advance!!.This is the first time I'm touching anything involving suspension so I'm going in a little hesitant.. but I'm sure it'll be just fine once I see the difference from stock.
Jeff_
Scottsdale, AZ & N. Idaho
If you're contemplating the 5100's I'd suggest ordering them now and hope to receive them by summer.
I have mine on order (since January) and I'm hoping to fit a 275/70/18 BFG K02 on my Tahoe after I put them at the highest setting.
Tiki
1” spacer with ride like stock. UCAs are not 100% necessary but are a good idea; you’ll need to ensure the UCA clears your wheel and tire combo.
Tiki
You’ll clear. I believe mine are second from top setting, same tires.
Jeff_
Finally had the chance to get them installed.
Took probably 4 hours. Always quicker to do the second side after you spend so long figuring out how to do the first side.
Hardest part was getting the strut lined up just right, needed to do a 180 after the first time I went to install it.
Next most important part was keeping track of which way the top of the strut was facing when you pulled it out. the 3 bolts are space apart differently. Two are 4.25" apart, and one is 4.5" apart. Gotta get it just right.
I rented a spring compressor from Oreilly's and that was the most stressful and exhausting part.
Anyway, love the way it's turned out. Night and day difference in driving characteristics - zero sloppy feeling when turning or when going over a dip/bump.
Glad I waited so long for these - worth it.
Pic attached, top is stock, bottom is with the 5100's at the highest setting.
STORMIN08
It is almost an identical shock minus over all length.
The valving is very similar.
CJF2019
Hi - Nice looking Suburban. Are you able to tel me what tires are on the vehicle in this picture. Much appreciated.
MTDreamin
Utah
Tiki: Your rig is exactly what I'm looking to do with my new to me 2018 Burb LS. I posted in another forum about the difficulty finding people posting exactly this info on this forum, like I was able to find when I did my 4Runner Bilstein 5100s a few years ago.
Just to clarify, you think you're on the 2nd from top setting on front and rear, and nothing else but the Bilstein 5100s all the way around -- no modified UCAs, spacers, etc.? Thanks for the info!
Tiki
Correct.
lucas287
Anyone in the Northern Virginia area want a brand new set of Bilstein 6112? Part #47-251922.
Fully assembled too with new mounts.
Ended up selling my Tahoe for a Silverado before I ever installed them.
olyelr
Elk Rapids, MI
Dont they fit the pickup too?
Bentley95
