Trans cooler seals
Tiredmechanic23
I cant seem to find a source for the seals where the trans lines go into the thermostat block or the ones for the block where it bolts to the trans. Ive developed a small leak and just want to put all new in.
I did find one seal option from the block to trans but it seems there were 2 styles. One that press/push into the trans or a seal washer style. I could only find the washer style for sale and my trans uses the pushed in ones that I can not seem to find anywhere.
exp500
GM GENUINE 24272475 Does this have what you are looking for? Post some info/pics so somebody can look it up!
T
Tiredmechanic23
Hard to post pics of seals I cant find info on and im not pulling the thermostat block off the trans to take a pic when its already leaking as that just inviting it to leak worse when it fails to seal even more...
yes that part grouping has the seals in it. The little push in ones in the top right.
exp500
So you like looking at part number pics but don't want the part? If we knew exactly what you are drivin might be able to narrow it down to individual seals if available. Otherwise, GM Parts Direct.
T
Tiredmechanic23
what im driving is in every post... Right down at the bottom where it says 2016 tahoe... I mean is that not clear enough? I also said what seals in that picture. If available is the problem they do not seem to be a easy to find part which is why this post was made to see if anyone knew of a source other than the normal suppliers like GM parts direct which has already been looked at. You seem to have a reading issue since I have my vehicle info listed and stated which seals in the pic im looking for.
a1parrothead
