bigfutz
I’m getting annoyed by this rattle in the rear driver side door on the wife’s 2017 Burb. Any ideas what it might be? Do I need to just tear it apart and see? I haven’t pulled panels on a vehicle this new. How many clips am I going to break?
Denaliz
Frisco,TX
Replaced Skid Plate And flaking chrome good trim piece today (plus bunch of audio enclosure upgrades, deadening and wiring but that’s another story)
I got tired of looking at my busted skid plate and finally ordered a new one. 4 bolts to remove and replace with new one.
7C64953A-14C9-4BD3-BCAF-23EC0E3DD5AA.jpeg 3AD0D45F-8DBC-4C38-9545-213D1215C974.jpeg C31CFE98-B52E-4487-9214-71705E95AB9C.jpeg 15D7354F-CD37-4E15-86E0-F1A607B57FC9.jpeg
Not a why really, just a question of technique.
I guess if you want to go through a bunch of extra work just to be more comfortable? I mean valve springs are pretty easy to do with the heads in place. I can do them in a couple of hours or so. #7 & 8 cylinders are the only two that are a bit of a reach, the others are easy.
St. Louis
View attachment 272679 View attachment 272680 View attachment 272681 View attachment 272682
I think that's a splash shield. I don't think the plastic would hold up well as an actual skid plate.
ls1frc
Yeah not saving work at all pulling the heads. The head/block/bolt hole cleanup is an hours long job as is on it's own.
Sparksalot
Bastrop County, Texas
Funny you say that. I’m fabbing a light gauge piece of sheet metal to back it up right now. Not so much for rocks, but other pokey things encountered off the beaten path.
Sparksalot
I know it possible to change them in place. I’ve always had the heads off because I was grinding valves at the same time.
Just Fishing
Can't fix stupid
Utah
Changed the oil and then I got to work on this.View attachment 272710
I got that when i first got my hoe.
Everywhere said "auto track II fluid" in the t case.
Me: i happen to have a few bottles on hand, so i used it
Man that t case was not happy at all.
Once i put the correct atf in there, all of the issues cleared right up. :D
Just Fishing
Can't fix stupid
Utah
And i kicked the vette out of the garage again.
I need to organize a bit first, but the hoe is about to get the oil pan pulled.
I'm also scoping out some nice used engine hoists.
Found a super heavy duty one not too far away from there, but it does not fold...
Looks like you could pull an entire car with it. :eek:
All depends on the transfer case as to which fluid to use. Mine takes AutoTrac II.
St. Louis
Either @Doubeleive or @kbuskill bought a metal one with louvers stamped into it. Thought it was pretty pricey though, but looked nice.
I bought the OE steel transfer case and front differential skid plates made for the trucks or Z71s and put them on my 2012 Denali. The holes are already there.
j_jerry79
