5/7 drop bishes
M
Max
Mile High
Denver
Doesn't look progressive like my 5305. I'm fairly certain the nnbs sit the same or slightly higher than the nbs based on the drops I've done on new bodies. I do love my 5305s tho, best riding coil I've found on these trucks hopefully the 4230s ride nice or better with the helper bags and about 20psi to bump up the spring rate. I hope to get the truck perfectly level at all 4 corners with the isolators and helper bags, tires have to tuck just slightly and I'd be so stoked.
Modded
That Guy
I unsuscribe from this thread, if I stay here (considering I am perfect level right now) I will end up re-dropping the rear for the third time, then front again to avoid Cali Lean, screw that.....
M
Max
Mile High
Denver
My boss is staying late Thursday to work on some stuff so I'll swap the springs in after hours. Talked to Bill at Fox today and found some shocks front and rear that should work well, non reservoir black and shiny bastards that are cheaper than I expected. I'll spend more money on shocks than my spindles and coils lol.
skyhighsami
What shocks are you going with the Bilsteins or the Fox? I need some new shocks and I am lowered 3-5 and thinking (if the wheels clear) maybe going another inch but I have to have a better ride. With the shocks having a bumpstop do you need the Z71 BS? Also what coils would you think would lower the back of a Yukon XL 5 1/2 or 6 inches and have a super soft spring rate yet corner really well?
M
Max
Mile High
Denver
Foxes. I'm thinking an airlift wireless air kit, about 15-20psi on helper bags, + these belltech coils will ride firm but soak up the bumps. I will have to notch my frame but it was inevitable, lowest static drop is what I'm after no matter what I have to cut. I really like these bilsteins but feel the foxes will ride better, still contemplating what to do for front shocks I may have to relocate some shock mounts to gain some travel.
COTahoeLS
Senior Member
Colorado Springs, CO
Bite it!!!
I hate knowing a brother is north of me riding in that badass Denali. I gotta come up and visit you again soon to drop more coin.
-E
Nickleahy23
Portage/Menomonie, WI
i cant wait to really like some bilsteins lol
skyhighsami
How much are the Fox shocks compaired to the Bilsteins? Which rides the more firm and which is the softest? I want the truck to ride just a little more "sporty" than stock if that makes sense.
M
Max
Mile High
Denver
Foxes retail for $150, bilsteins are $84/ea. I'm calling bilstein tomorrow to check on our purchase orders, thinking my shocks are holding the ass up because I installed the new coils tonight and it only dropped about 1/2" but the spring rate seems to be higher on these which is great. I now have approximately 1" of uptravel on my shocks and the axle is about 3" from the frame. I was hoping for a bit more drop but it is a good thing if these coils are stiffer once settled. Once I get the shocks sorted out, section 1/2" out of the panhard to relocate the axle, and cut some new sway bar links it should ride pretty nice and I'll finally be done with the damn thing. I don't have pics of it on the ground since it was getting late at work and I wanted to get the hell out of there, but here is a pic of the two springs old vs. new:
Here is how the truck sat Tuesday, hopefully this gives me the extra inch I'm after or I'll just bag the damn thing :crazy:
Modded
That Guy
Still looking sick, disappointment it did not get to where you wanted, did you try taking the shocks off and letting the truck sit on the coils only for a while to see if its the shocks or coils?
M
Max
Mile High
Denver
Thanks guys, it has come a long way. I didn't try pulling the shocks since it needs time to settle but the new bilsteins should solve any hangups I may be having and maybe ride better than these (which would be amazing). Gonna be funny with HD bilsteins up front and the silver 5100s out back lol.
thehoe92
fo sho
The916
so that just struck my curiosity..
jack the back suspension up let the shock bolts loose and let the jack down so its resting on the springs
is that safe to do, I mean obviously just sitting and not driving
but I kind of want to try that now to see if my shocks are really holding me up
sorry for the thread jack
M
Max
Mile High
Denver
Nope that is a safe thing to do, I just didn't want to mess with it since I'm replacing them shortly. Just be sure to use jackstands :cheers:
briannorris
