Valve lapping
mdmcinti
Nevada
When I replace them cam and lifters on my Yukon xl. Since then heads are going to be off, I was going to clean and rebuild them on my kitchen table. I was seeing videos and threads where people would lap the valves when doing this. I also have read where a member on here did a cam swap and afm delete on his 6.2 Denali and and machine shop didn’t lap the valves because they sealed perfectly fine. I was planning on removing the valves and doing the scotch brite cleaning method with a drill and the help of of an acetone/tranny fluid mix ( there is a video on YouTube of this working wonders on carbon like magic). What are your takes on this?
Btw I am going to drop in a summit 8718R1 cam into my rig since it can run on stock tune and springs until I have funds for a tune and some ls6 springs.
If you're motivated enough, and the heads are already off--why not? I can't see it hurting.
taylorb71
Central North Dakota
If you take the valves out just make sure to keep them in the same holes they came out of. Shouldn’t need to lap them if they are in order.
What I did was carefully use a 3m bristle brush and a good power wash with purple power (diluted of course) and they came out pretty good compared to what they were before. Engine was a sludge puppy
mdmcinti
mdmcinti
Nevada
I was planning on doing one cylinder at a time. Removing valve spring, the seal/seat the valve. Clean and put In back together. The lapping took and compound is only $10 total and probably adds a few extra minutes to the reinstall time.
mdmcinti
mdmcinti
Nevada
Would it be okay to reuse the stock springs for now until I funds to put some ls6 springs in? I don’t run the truck hard or anything and it’s going to be on factory tune for a while so it won’t go past 5500 rpms or whatever it maxes out at. The improvement I want to see from the cam is more torque and not having to down shift when I go up grades on the highway. The motor has 254k on it. The inside is in great shape because I replaced the oil pan gasket and it was clean just the typical amber color on the components but no sludge.
They may be okay, but for how long? They already have a quarter of a million miles on them, and now they're about to be getting squashed with different harmonics. If it were me, I'd get the LS6 springs now and swap 'em while you have the heads off- it's way easier than with them in the vehicle.
Are you getting the cam new from Summit? They sell it as a kit with springs and valve stem seals.
mdmcinti
mdmcinti
Nevada
Yup that’s the plan to get the cam from summit racing. I saw that package for $394. I am unsure about their valve seals. I have heard nothing but good things about the fel pro seals. On my rockauto parts list I can get Melling valve springs for $54 and fel pro seals for $19. Still $20 cheaper than the summit cam package. Hopefully they go on sale soon.
mdmcinti
mdmcinti
Nevada
Did some research and it turns out that cam is advanced 4 degrees so it’s intake center line is at 112 degrees. Basically it gives the cam low end and the exhaust comes later. I might consider it if it’s still on sale lol.
MLRTYME
Re: Lapping Valves--- When new, valve seats and valve heads will wear a unique pattern with one another as the engine runs (similar to the old school flat tappet lifter and cam lobe wearing a unique pattern) and this helps provide the seal. The concept of lapping basically clears that pre-worn surface and builds a new unique wear pattern so the valve seat and valve head can start fresh. Most commonly done when someone has the valve seats refaced (but is reusing old valves) or vice versa. Lapping isn't a terrible idea, but if you keep the valves in the same cylinder going in as the one they came out of...and you're not doing any resurfacing to the valve seat...the benefits will be negligible.
If you have some time and you don't mind a little elbow grease...it's not a bad thing. Just know that the effort may provide minimal results if not necessary.
mdmcinti
mdmcinti
Nevada
Thank you for that explanation. I probably won’t have to worry about doing it then since I am going to remove one valve at a time to clean an then reinstall with new seal and spring, then move to the next valve. Plus it’s another $10 I don’t have to spend on materials and then have to explain to the wife lol.
JamesinAbilene
