The indignities...
St. Louis
Tape a note to the steering wheel, or get a refrigerator magnet and put it on the door near the handle whenever you have the cord plugged in to remind you that its plugged in before getting into the vehicle
Or mount a recessed male receptacle in a position so you'd harmlessly tug it unplugged when you backed out. You'd have to always pull in when you parked, though.
Really, you could just tightly secure your extension cord (to a workbench leg?) and the tender's power cord to the frame or inner body with just enough slack to keep it from dragging the road and plug it in. If you forget and back out, it'll just pop loose and the cord will hang.
I don't like the idea of starting the engine with the tender hooked up so I'd just do whatever to remind myself. Closing the hood but just until the safety latch catches might work for you if you think you'd notice it. You'll lose the remote start feature with the hood popped, though.
W
wsteele
I think the most promising hood down setup for my situation is probably the pigtail out the front of the grill. It will be easy to setup a clip for the pigtail to conceal it and make it easy to retrieve and hook the tender up. I think something like your idea of securing the charger side of the pigtail connection, such that it will harmlessly pull it out if I did forget and back out without disconnecting it, is likely about as good as I could do for the absent minded situation. I too don’t like the idea of starting it with the tender connected, but I suspect nothing bad will happen to the charger if I did forget and do it.
I think for now, I will use the clips and do hood open thing. Maybe it won’t be as big a deal as I have in my head right now. Something about leaving the hood open all the time seems kind of untidy.
Truth be told, I am not sliding down the pole and peeling out to go fight a fire, so maybe the open hood will work. :)
I start mine with the tender connected all the time. It just goes into its analyzing cycle.
TxVet33
Abilene, TX
The other day I replaced the alternator because the original unit was beginning to really make a ruckus. It seemed a tad weak on charging, but certainly was working.
Yesterday I was checking my emissions monitors with my cheapie ODB scanner and noticed the voltage levels seemed pretty low.
I had replaced my battery about 16 mo ago with an AGM unit from Napa. The truck starts fine, but the nominal voltage seems to hover around 12.2 to 12.3 after a normal jaunt to the grocery store, Home Depot, etc. My first reaction was maybe my old alternator was not as good as I thought it was and my 16 month old AGM had taken a real beating in its short life.
I then wondered if I picked up an abnormal parasitic drain along the way, but nothing looks out of the ordinary after a few hours of rest.
My final conclusion is I just am not driving the truck the same during these Covid times and the battery rarely ever gets a good solid charge. I realized we aren’t going anywhere far these days, so the poor battery just isn’t getting a full charge.
I saw that Costco has a 4a automated charger/tender for like $50. I think I will pick one up, hardwire a pigtail and try and find a clean spot up front to access it with the charger.
Oh the indignities, a battery tender! Next thing I will be shopping for depends... :(
Or maybe “new” alternator is hinkeee
W
wsteele
I noted a few things while driving around today, after my last post above.
Before getting in and starting the engine, I was measuring the draw down from full charge to a place I see it nominally settling after each recharge cycle, checking voltage with a meter each hour or so. My goal was to observe how quickly the voltage bled off due to the normal parasitic draw.
I had the meter on the battery getting ready to make my final measurement before heading out and starting the whole cycle again, when my wife opened the door to get the dogs into the back seat. Wow, the voltage dropped a lot, like a half volt. At that instant I realized all my previous measurements of battery voltage and conclusions regarding its state were wrong, as I was measuring the battery while still connected to the truck. The truck's systems draw from the battery at various rates as systems slowly shutdown or power up (like when you open a door). Lacking any clear documentation of what happens when and how much those things represent in power draw, measuring battery voltage without the battery being disconnected from the truck is a fool's errand, I think.
I am intrigued enough about where my battery (and charging system) is at, I think I will take the time to disconnect and reconnect the battery when taking measurements. This will require me to do a fair amount of TPMS relearning, but I have a big compressor, so it shouldn't actually be a big burden.
Another thing I finally got to see today while driving around was the RVC reacting exactly like @iamdub said it would. When the voltage dropped well below 14v (on the dash, sometimes looking more like 10v), it didn't appear correlated to the RPM of the engine or even when I turned systems like the AC, radio, rear window defroster on and off, it just seemed at times to decide apparently randomly, when to charge the battery and when to discharge it.
Not sure anything fundamental has yet been resolved in my understanding, but seeing how much draw is triggered by just opening a passenger door, lead me to really want to know if my BCM has that sw upgrade called out for 2007 model year's with charging issues.
Some fun.
Some fun.
All them incandescent interior lights pull some power! Was the engine running when she opened the door or were you running straight off the battery?
Could you go to a battery store, maybe even a golf cart service place and have them test your battery? I wouldn't go to an auto parts store to have it tested. Call me a cynic, but I believe their equipment is biased towards condemning batteries to help push a new battery sale. I'd believe that a battery or golf cart service place would be more likely to have equipment designed for accurate data.
I've never checked the voltage drop on my NBS when opening a cabin door, but doing that draws about 4.5 amps from the interior lights as well as wakes up a few modules (they do go to sleep relatively quickly after closing the door, as long as nothing else is operated).
When you're testing the voltage of the battery, it should rest for an hour or so after being charged so it's the resting voltage that's being tested:
https://haynes.com/en-us/tips-tutorials/how-test-car-battery-multimeter
W
wsteele
Great idea, I will look around. I think there is a guy not far that deals in used golf carts. I don't think he has regular hours, but I will try and catch him. I bet he has the equipment.
The engine wasn't running, in fact the key was out of the ignition.
W
wsteele
I watched the "draw" pretty rapid for the first few minutes after shutdown and tapering off. I didn't know it was an hour, but that does make sense from what I have observed.
I did find a TSB for my model year for a BCM SW upgrade that addresses charging and battery issues. I am wondering if maybe opening the door triggers something else in the BCM that it shouldn't, hence causing a higher than normal draw. I don't get my Tech 2 for about a month, so I think I might drop by the dealer and see if my 2007 Yukon has that software rev.
Tonyv__
Bucks county PA
Just went through something similar with my wife’s car. It barely gets driven now with COVID. She had intermittent starting problems last month. Put it on charge overnight and it’s been fine since. I worry that my Yukon is on the same path. But no signs of poor battery yet
If I recall correctly, the Tech2 can show battery condition. @swathdiver's mentioned it a few times. He's been MIA lately since his bout with COVID. I hope he's still improving and just taking a break from us monkeys.
Harold Pierson
Costco sells depends also, it's what happens with age.
W
wsteele
Thanks for the tip, I will keep that in mind for when that time arrives. Of course, when that time arrives, I may not be able to keep much in mind. I wonder how far out Apple will let me schedule a reminder on my iPhone? :)
W
wsteele
I did a little testing over the evening and this morning, armed with the enlightenment of the apparent drain the lights and systems place on the battery when just a door is opened.
First thing, I do like the CTEK charger/tender I bought. I don’t know if the “conditioning” mode worked some or the charger section just does a better job than my Die Hard big charger does, but the starting voltage measured with a DVOM, after the charger indicated a complete charge and just after I disconnected it from the battery, the battery reads 12.91v, much higher than the same condition with the Die Hard charger.
I left it overnight without the tender and just the truck’s normal parasitic draw to work on it and this morning the battery showed a solid 12.63v before touching a door handle, etc. That is quite a bit higher than the exact same timing of measurement after I had used the Die Hard charger and left it overnight.
I then opened the drivers door and went back to measure and the battery showed 12.18v (lights on in the cabin, CD searching in the Nav/Radio, who knows what other systems spooling up, etc.
After closing the door and letting the lights fade out, the battery climbed back up to 12.3v. I am going to wait a little over an hour and remeasure, hopefully with all the systems spooled back down, I will be back closer to the 12.6v starting point.
I did go back and check my receipt and I have one more month left on the free replacement guarantee from Napa for it’s Legend AGM battery, so I think I will take it back and have them test it. With the free replacement sitting there, I think maybe I will get a good shot at an honest assessment of its condition. :)
Right now, if the battery recovers anywhere close to the 12.6v, I have to conclude it likely is fine and all my fears were driven by measuring the battery still connected to the truck, with systems not fully spooled down.
In the olden days, when you turned the lights off and closed the door, things were off... :)
W
wsteele
OK, final update.
I went out after about an hour and a half of everything powered down (door closed) and the voltage has climbed right back up to 12.62v (as measured with a DVOM on the battery).
I have to conclude the battery is fine and what I was seeing were voltage reading on the battery terminal while the systems in the car had not fully spooled down and the battery had time to recover.
I am going to still pop it out and take it down to Napa for a test, but I am pretty sure the problem was with my lack of understanding how all the systems are triggered, how much power they use when spooled up and how that is reflected when measuring voltage at the battery posts.
I swear, I learn something every day.
PS - I am still going to use the CTEK tender as it may have actually done some good on the conditioning front as the peak static voltages after everything is spooled down is higher than I was seeing in my blind man's bluff mode of testing I was doing before. Maybe it will actually allow me to get past the prorated warranty period of that battery for once, since I replaced the original factory unit (which lasted like 8 years).
OK, final update.
You have to let the battery rest for at least an hour after removing it from the charger to get an accurate resting voltage. That 12.91V taken immediately after disconnecting the charger is irrelevant. So, don't think your battery is failing anything by not maintaining that .28V.
Conditioners can't really show much improvement in just one night, unless there's really nothing for it to recondition. It's a slow, gradual process involving dissolving. I doubt NAPA has equipment so advanced that they can detect such a minute degradation in capacity. However, having them measure it now will give you a baseline to compare if you were so inclined to return after a month or so of keeping it on the CTEK to see if the capacity goes up. This would tell you (1) your battery's true condition and (2) if the CTEK helped any. In the meantime, try to keep it on the CTEK for as long as possible with no interruptions.
W
wsteele
Thanks, yeah, I was pretty sure the "conditioning" functions probably couldn't do much in a few cycles. The peak voltage right after disconnection fades really quickly, and is way above all the charts I have found say is 100% anyway, so I assumed it was a very temporary thing. I will say though, I think the CTEK may actually do a better. job of charging the battery because everything is measuring higher than I ever got after a rest periods with my Die Hard charger.
I am thrilled with the 12.62v resting rate after all the gizmos spool down, so will continue to use the CTEK all the time. Who knows, maybe when I take it down to Napa for the test, if they say it is bad, I will whip the receipt out and maybe get a new battery in the process... ;)
I appreciate the guidance along the way.
enigmaspeed27
