The indignities...
wsteele
The other day I replaced the alternator because the original unit was beginning to really make a ruckus. It seemed a tad weak on charging, but certainly was working.
Yesterday I was checking my emissions monitors with my cheapie ODB scanner and noticed the voltage levels seemed pretty low.
I had replaced my battery about 16 mo ago with an AGM unit from Napa. The truck starts fine, but the nominal voltage seems to hover around 12.2 to 12.3 after a normal jaunt to the grocery store, Home Depot, etc. My first reaction was maybe my old alternator was not as good as I thought it was and my 16 month old AGM had taken a real beating in its short life.
I then wondered if I picked up an abnormal parasitic drain along the way, but nothing looks out of the ordinary after a few hours of rest.
My final conclusion is I just am not driving the truck the same during these Covid times and the battery rarely ever gets a good solid charge. I realized we aren’t going anywhere far these days, so the poor battery just isn’t getting a full charge.
I saw that Costco has a 4a automated charger/tender for like $50. I think I will pick one up, hardwire a pigtail and try and find a clean spot up front to access it with the charger.
Oh the indignities, a battery tender! Next thing I will be shopping for depends... :(
Lol. I keep one in my bagged truck in the winter because I don’t drive it in the rain but my 02 seems to stay charged with just my runs to Home Depot or the grocery store.
Could it be that your alternator is charging so strongly and your battery is recovering its voltage so quickly that your short jaunt to the grocery store is enough to fully recharge it after the cold start, so the RVC system is reducing the alternator's charging rate, dropping the voltage?
I'd still keep it on a charger, maybe even one with a desulfation mode, just 'cuz.
W
wsteele
It could be. If I were better with auto electronics I might even be able to find out... ;)
The battery I have now might be past it’s prime already and the tender will only allow me to extend the glide slope some. But once I have the wiring the way I want it, it will be pretty easy to keep the tender hooked up. I did see the desulfation mode on some of the ones I looked at, I will have to see if the Costco unit has it. At $50, it looked about half what the same unit was selling for on Amazon .
I would say if it’s starting fine you’re probably fine as it is. But it definitely wouldn’t hurt to keep it on a tender. I use an OptiMate 6. It doesn’t say it has a desulfation mode but it says it will save a dedulfated battery. Seems to work great.
W
wsteele
Yeah, the battery is definitely on the more marginal side. I disconnected it, charged it with my Diehard electronic charger, read it fresh from the "fully charged" light and it was 12.81. Two hours later, it is down to 12.6. I will check it tomorrow morning, before I hook it back up, but I suspect all the tender will do is maybe extend its useful life a little. I think maybe I should have swapped that alternator out sooner. I did procrastinate on it for quite a while.
As a test, you could unplug the RVC sensor and see if the voltage goes up and stays up. It's on the negative battery cable, not far from the battery post.
W
wsteele
Thanks for the tip, I will test it.
I went ahead and spent an extra $30 to order a high tech tender that supposedly does all sorts of battery conditioning (Sulfation, etc.), it was good enough for Jay Leno, so I thought I would give it a try. :)
Link?
Thanks. I’ll probably get that one if I buy an AGM battery for the Silverado. It’s just running a lead acid one now and it and the optimate has been working fine. But I’m sure it’s only a matter of time before it needs a new battery with the way that truck is driven and the fact it always has a high current draw with it running 2 Viair 485 compressors.
W
wsteele
They have a confusing array of products, from fairly cost effective to ridiculously expensive. The fact that a number of the very high end car manufacturers include one of their tenders with the purchase of one of their cars, seems to bolster their credibility to some degree. In the end, volts, amps and watts, along with battery chemistry is a pretty well understood science, so I think maybe some of their most far fetched claims may be just that... ;)
W
wsteele
I decided before disconnecting the RCV sensor, I would check the charging voltage with a meter, versus just relying on the gauge in the cab (which has always shown good voltage). At idle, I was getting 14.5 -.7 volts to the battery, so I think I don't have a problem with the RCV system limiting charging voltage. I then decided to drain the battery for a half minute or so (lights, seat heaters, fans, etc.), then start it, running all my normal accessories, let it idle for 10 minutes, shut it down and check the voltage at the battery immediately. The voltage at the battery was 12.7v, which is .4-.5 volts above where I have read it each time after a few hours.
I think my problem is a battery that has seen it best days. It might be because I had neglected it for too long before I swapped alternators or might be just a crappy Napa AGM battery. I did see a TSB GM published for 2007 Model year Yukons (and all others of this ilk), where the BCM needs a refresh to update the power saving algo's. I don't know if my BCM is affected and if it is, whether it might have had the new rev sw flashed, so I will ask my service rep to check. Maybe I will get a chance to use my new Tech 2 to update my BCM, if it ever gets here from China.
Also, maybe when I get that fancy tender, the conditioning sw it has might help restore the battery to some degree. Hope so.
I should clarify: I didn't mean that you may have a problem with the RVC. I just meant to remove it from the equation to see if your battery and alt were actually fine and your lower voltages were just because it was cycling as normal. That's what it does- it reduces or stops the output from the alternator to not needlessly overcharge the battery. I don't think it's active at idle, so your volts would be the normal and expected 14.5ish. If your alternator is charging strongly and your battery is taking that charge quickly, as in during your short trip to the grocery store, the RVC would reduce or stop the charge from the alternator and let your vehicle run or run more off of the battery, and this may have been when you noticed the lower voltage- during one of those "charging off" cycles.
I still agree to the tender. With a low-amp model, you should leave it on the tender as much as possible. According to what I read, I should leave mine on for at least two weeks to really take effect. But, mine is a 1.x amp model. Yours is about four times the power, so it should do whatever it's gonna do much quicker.
W
wsteele
I am not well enough acquainted with how the RVC works to know if what I am watching on the dash gauge is a fair representation of what the battery is getting. Frankly the dash gauge slowly moves up to the mid 14v range right after startup and doesn’t move much from idle warm up, around town and back. I watched the gauge like a hawk in my afternoon around town today and the voltage was always over 14, rough guess at least 14.2v. If what the battery is seeing is a different voltage than I see on the gauge because the RVC is throttling the voltage to the battery, then I think your supposition that the RVC might be interfering with a quick recharge may in fact what is happening. On the other hand, if what I am seeing on the dash gauge is the voltage the battery is seeing, the RVC isn’t throttling the voltage.
Looking at what seems to be happening on the surface is the battery takes something above 80% pretty easily, but it doesn’t stay up there. It seems to discharge down to something closer to 50% (12.2-12.3v) very quickly. A chunk of that “discharge” will happen even if the battery is disconnected.
So it may be that the current battery condition is related to an RVC throttling voltage, a down rev BCM or maybe the more likely culprit a failing alternator left in too long which took its toll on the battery.
I am going to hold off buying a new battery until I get to see what possible effect the new tender might have on the clearly subpar battery condition. In the interim, I plan to see if my BCM sw has the update called out in the TSB.
Does that make sense? Or am I still missing some part of the picture?
Nah, we're on the same page now. I was hoping it was just the RVC doin it's thing and your battery actually wasn't bad. But, now you at least know of one other possible factor.
Just Fishing
Can't fix stupid
Utah
lol!
my issue is the short drives, and i usually have the heated seats on maximum, and the heater cranked up with the rear fan blowing.
I like to imagine it's summer time.
My hoe takes such good care of me! :)
W
wsteele
I appreciate the patience in explaining everything.
W
wsteele
So my CTEK charger/tender came today. It has a conditioning mode, theoretically reversing some of the degradation a battery might have suffered over time. It will be interesting to see if the reconditioning processes reverse any of the apparent degradation the battery clearly has suffered.
I got it hooked up and it seems to be functioning. It is a whole lot quieter than the Diehard battery charger I was using to keep recharging the battery between uses.
Right now I am mulling what hard wired location I want for the pigtail that will be connected to the battery for ongoing tender duty. I have mixed feelings about having a convenient and unobtrusive place for the pigtail (say coming through the grill) as I can see myself in a preoccupied moment just backing the truck out and dragging the whole kit and caboodle down the street before I realize I forgot to disconnect the tender. That is one positive of having to open the hood each time to hook things up. I won't forget to unhook things with the hood up. Decisions, decisions...
Or you do like me and open the hood to hook the tender to the connector and then shut the hood so it’s locked inside and can’t get stolen, and forget it’s hooked up for a sec as I start to drive away. Luckily I heard the cord get tight and stopped. Haven’t forgot ever since though. I don’t have the tender itself mounted but I like to be able to just connect the little pigtail they give you to the harness I have permanently mounted in the engine bay, lay the tender inside and close the hood.
Charlie21ny
