Stabilitrak issue my journey so far.
Taheezy_88
Taheezy_88
Thanks for the reply IamDub. I watched the video and it was great info. I am currently shopping an AFM DOD delete rebuild kit but cant find an exact one for my non vvt 5.3l. I will be locating a local mechanic to do the labor.
Anyone have a link for a afm dod kit with cam non vvt 5.3l or a great parts list to go off for rebuild?
Would I need the afm disable tuner also with the delete kit?
I cant post the link of the kit I found to confirm with you guys it is ideal.
AFM DOD Delete Kit with Choppy Idle Camshaft for 2007-2009 5.3L Chevrolet GMC Truck SUV
by ams racing
The problem with budget kits is you don't know what lifters you're getting. IIRC, there have been two cases just on this forum within the past year where someone bought one of these budget kits (I think one of them was from AMS Racing) and had lifter failure very soon after. The lifters are the most critical component in the delete. If there's a lifter failure, it requires removal of the heads to replace, which will cost you not only the cost of replacement lifter(s), but also another set of head gaskets, exhaust gaskets, head bolts, coolant, etc. It's definitely worth it to spend the money on quality lifters. I'd stick to GM (ACDelco or Delphi). Just confirm that they are genuine and not knock-offs. Advertisement wording is tricky.
Also, that kit would require a custom tune, adding to the cost. If you're not after more power, you can get an L33 cam and the only tuning you'll need is to have AFM disabled, which can be done for about $65. When the delete is finished, you'll be ready to roll. You can get send your PCM off to have AFM disabled now and just drive as normal, but without AFM operating. This will buy you time to collect your parts or kit or whatever you decide to do rather than rush to make a decision to stay ahead of a possibly pending failure.
If you do wanna upgrade the cam for power, you're gonna need a custom tune. You can find a tuner, pay them to license your vehicle and tune it to shut AFM off, have the delete performed, then have the tuner tune for the cam. Or, you may have a performance shop do the delete and tune all in-house to simplify the process. It depends on what's available in your area.
Taheezy_88
Taheezy_88
What are the possibility of me needing a new cam? I stopped driving the Tahoe the day I heard the knock.
and if No cam replacement what do I do with the VLOM? replace or Valley cover?
Pull that VLOM off and see if you can see any damage to any cam lobes and lifter rollers, particularly the #4 exhaust side. If all looks fine and it's just a collapsed lifter, try to unstick it. If you get it unstuck, put it back together and fire it up. If the knocking is still there, then either it collapsed again or the knock is somewhere else. Have you tried rotating the crank back and forth few degrees each with it as-is to see if there's any clanking? If the knock is gone, then it was that lifter and it could happen again, so you'd wanna disable AFM so you can (hopefully) safely drive it until you can do a delete or just let it sit until it's deleted. You gotta determine the source of the knock to see if it's even repairable/deletable.
Taheezy_88
Taheezy_88
Iamdub tomorrow I will pull the VLOM and rotate the Cam and inspect the lobes. I was just watching a youtube vid of the same situation guys shows how to check lobe and rod to see if the rod ate at the lobe.
Thank you again for the knowledge its guys like you that save guys like me a headache and $$$
Taheezy_88
Taheezy_88
front cam
Taheezy_88
Taheezy_88
Cams have some normal wear but I'm not sure if it was damaged.
Taheezy_88
Taheezy_88
When taking cam off and sprocket is their any timing issues I need to worry about or is removing the the sprocket chain and cam simply bolt off and bolt on with the new cam. My Chilton manual doesn't say much but that only a professional should do it because any mistake can cause severe engine damage.
Sent from my SM-S215DL using Tapatalk
The sprockets can only go on one way. The crank sprocket is keyed and the cam sprocket has a locating pin. You hang the chain on the cam sprocket with the dot at the very bottom, rotate the crank until the dot on the crank sprocket is at the very top, hook the chain on the crank sprocket and keep slack out of it while you mate it to the cam. You'll have to turn the cam to align the pin. If the cam sprocket dot isn't at the very bottom, in perfect alignment with the dot at the top of the crank sprocket, then lower the cam sprocket to let the chain hang loose enough to go one or two teeth whichever way it needs to go, then pull it back tight and mate it to the cam. All you need is for the dots to align with the cam sprocket seated to the cam.
Taheezy_88
Taheezy_88
No i didnt really get a good luck at the lobe on cylinder #4. I went ahead and prepped the heads today for removal tomorrow Ill only have the head bolts and alternator bracket to remove. I will pull the heads tomorrow and get them to a local machine shop. Rods looked good will be replacing them even still but still wonder why #4 rocker was loose? should I just replace all rocker arms as well? I will most likely.
Im going to go ahead and start the AFM DOD delete process. Ill be using a stock cam and will have my ecm tuned by Brendan @ http://www.lt1swap.com/afm_delete.htm
Kit: https://sdparts.com/i-24048327-sdpc-dod-afm-delete-kit-for-5-3l-ls-engines.html
Cam: https://www.summitracing.com/parts/...g0su0K0m9UqW_lcgpxt29usvPBbUcxvxoCQqkQAvD_BwE
Second verification of these parts is greatly welcomed.
*wish i could go more performance on the CAM but no local tune shop
Sprocket? will I be using my stock sprocket or would that need to be replaced for the new cam?
Given your other symptoms, I'm banking on that rocker being loose due to a collapsed AFM lifter. You could do more troubleshooting to come to a diagnosis, but none of it matters if you're going straight for the AFM delete.
I'm a fan of having AFM tuned out by that guy cuz it's super cheap. It's only a fraction of what a Range costs and you don't have the issues a Range can cause.
SDPC doesn't specify what brand the lifters in that kit are. I see they offer Delphi lifters for an additional $159.80. I would STRONGLY suggest getting genuine Delphi lifters. Yes, their price (and most all GM parts) has skyrocketed since the GM strike and then COVID. But, they're worth it to not have to go back into the engine (new head bolts and gasket(s) to replace a failed cheap knock-off lifter while hoping it didn't wipe out a cam lobe.
That cam is slightly smaller than the original. It'll work and be fine and you'd probably not notice any loss of power. I wouldn't let it hold up the project, but I'd look for an L33 cam, new or good used condition. The L33 cam specs are identical to the stock LMG specs, just without the AFM lobes. On the other hand, since the heads are going to a machine shop, they should be resurfaced as standard procedure. They shouldn't have to take any more than around .003" to .006" to get a flat surface and appropriate RA. But, since they're already being milled, you can have them deliberately shave off something safe like .010" to slightly bump up the compression. This would make up for any loss the smaller cam might bring. Unlike a cam, it would add power across the entire rev range. To be on the safe side, I'd run 91-93 exclusively. Really, these things need 89 at a minimum even in 100% stock form. Running high octane would cost a few bucks more per tankful, but you'll get used to it. The better MPG would offset some of that cost and you'll appreciate the extra power. If you do get an L33 cam, you'll need the 3-bolt cam sprocket that has the 4X reluctor that the GenIV engine runs on. This is GM #12586481. You'll also need the three cam sprocket bolts, GM #12556127 (you'll need 3). I always use ARP for the cam sprocket bolts: #134-1003. If you go with that Summit cam, you can reuse your stock cam sprocket, but get a new bolt.
The stock rockers are fine. At 147K maintained miles and with keeping it a stock build, they have lots of life left in them. With the cost of GM original parts the way it is right now, replacing them would be a splurge, IMO. I'd run 'em if they all checked out fine.
On this build, stock push rods are fine. Roll 'em on a piece of glass to ensure none are bent. Inspect the tips for any roughness, indicating a lack of oiling. If they're all smooth and shiny, reuse them.
I have a decent amount of pics and details in my build thread if that would help any, at least with ideas and/or foresight. I started out with a stock AFM delete in mind, but a buddy messed that up for me. I ain't even mad, tho. lol
Taheezy_88
Taheezy_88
Thanks for the detailed response and part numbers definitely needed them. I will be opting for the Delphi lifters, and new rods.
I will opt for the l33 cam and after searching google this would be the correct part# ?
12583623
I will also be referencing your part numbers for the cam bolts and sprocket.
Bout to get coffee and pull these heads. Thanks a lot for the info be back with updates
12583623
Yes, that's the number for the L33. I was curious and had to browse to see if any new ones were available and at what price. They're all at least twice what they used to cost. I found some on ebay for $175: https://www.ebay.com/itm/GM-Chevrolet-LS-GEN-IV-Camshaft-Genuine-OEM-12583623-/163972635887. They have it listed as a GenIV, but it's definitely a GenIII if that part number is correct and that's the cam in the pics, so ignore that part. The 3-bolt cam sprocket you'll need to run a GenIII cam is about $25, plus the $10 sprocket bolt set, so you're looking at about $210 to run that cam. That cam from Summit is $124. Don't forget the new cam gear bolt, #11561283. Honestly, for the ~$75 savings, I'd go with that one unless I found a known good L33 cam for $100.
Looking forward to the updates!
BTW, I think you should start a thread to document your AFM delete journey. :)
Taheezy_88
Taheezy_88
Thanks ill start a new thread tomorrow. Working around the exhaust manifold to remove the heads was a b****. Im gonna need to do some heavy decreasing of the cylinder walls and piston heads
veteran111
