Good Upper Control Arms for 9 inch lift
McLeod Crouch
Any recommendations on UCA for a 9-inch lift? Kryptonite has some for $500 but is there anything not as expensive?
Rough Country has some for like $280 but they are for 2-3" or 7" lift and won`t fit due to the fixed angle.
Dustin Jackson
@McLeod Crouch Most lift kits are designed to use factory control arms or include control arms suitable for the application. Chances are with that amount of lift you will be using a combination of a lifted steering knuckle and lower control arm/crossmember/differential drop along with factory or upper control arms designed for 2-3 inches of lift. If you are already running a 9 inch lift kit then you will want to get a replacement that is similar to the one you are already using.
Tozan
Overlander
Beauregard, Louisiana
Dustin pretty much summed it up... The type of lift kit you have will dictate the control arms you can use they are not all interchangeable. Putting control arms not designed for your lift can cause major problems and in some case you may not even be able to install them due to clearance issues.
scottd
