Need more output from denali head lights and fogs.
Geoffsfas10
St. Louis
What is that mh1 projectors.
Like above, they are a bi-xenon HID projector, which means they also add a second set of high beams to the headlights. Now, they are a bit of an investment up front, but you can always catch them on holiday sales
https://lightwerkz.net/collections/universal-kits/products/bi-xenon-morimoto-mini-stage-iii-h1
There's some places that still have the denali quick retro brackets available. Basically you pull the stock projector from the headlight, install the bracket onto the new projector and drop it in place of the old one. Wire up the HID harness, add your bulbs and BOOM! easily 3x-4x the OEM output.
Heres pictures from the denali lights i did the swap in when I had my NBS sierra
full
full
full
They were so good that I only had my tahoe for 2.5 months before i bought a second set of headlights and did a much more complicated retrofit into them but again, the output is 10000% better
just the lows and fogs in the tahoe
full
fogs, plus both sets of high beams
full
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
full
full
full
full
full
And just like that ,I have another projects. Lol. Thank you for all the information.
Geoffsfas10
St. Louis
bigdog9191999
sw michigan
I still want to do this, but the stock ones actually work pretty decent for us, also having 6 on high I am sure don't hurt. but my housings are also starting to haze and I really don't want to spend the cash for new housings, just to spend more on brackets, projectors, and hid kit. although the results I know would be worth it. ( I have retro fit a few other things before, and am familiar with the results)
Try to polish the lens out.
bigdog9191999
sw michigan
I have considered this but am afraid that it may degrade them and make them worthless, but I could use that as an opportunity to upgrade too, so... maybe I will order some plates and try to get them polished up and drop some mini h1's in. maybe grab some standard Yukon lights to toss in while I am working on them.
but that also makes me think that maybe I should just grab some clear standard Yukon lights and retro those, but I just don't think they would have the right look for the Denali.
Leavitt
full
full
full
full
full
@Geoffsfas10, I'm a brand new Denali owner. I've had a new-to-me rig, 2003 Yukon XL Denali, for 6 weeks (give or take). I ended up here, looking for good information on headlights. Your pictures are astounding!
My rig has stock headlight assemblies, with some kind of HID bulbs in them. The rig came with them and I know nothing about HID. I have HID in low, high, and fog; the brand name is unknown to me.
My fog lights are useable and bright, I have no issues with them, in fact, I rely on them for everyday driving.
High beams are pretty darn bright, although not as nice (not even close!) as what's pictured in your pictures! (plus it takes 3 eternities to come up to full operating brightness) I can say with 100% certainty: have light envy!
Honestly, I could live with the high beams "as is". I came here thinking that if I could find a quality LED for the high beams, I'd get them simply for the "instant on" function, but these are impressive pics and now I'm trying to figure out how to duplicate what you've done.
The reason that I started searching the forum is that my low beams are so dim that I mistakenly believed that both bulbs were burned out. I literally have flashlights that are brighter than my low beams. This is my initial introduction to projectors, so I know nothing other than what I've seen here, but my projectors are seriously ineffective. I have to drive with the fog lights on because the low beams are so dim that it's just plain unsafe.
The pictures of your low beams are impressive! I followed the link that you shared: https://lightwerkz.net/collections/universal-kits/products/bi-xenon-morimoto-mini-stage-iii-h1 but there were so many options there that I quickly became lost, not knowing the answers to anything (let's be honest, I didn't understand the QUESTIONS, let alone the answers...)
The following questions are listed on the website:
1. H1 8.0 (LHD) vs H1 7.0 (RHD)
2. Hylux 2A88 35w vs XB35 2.0 (35w)
3. H1 HID bulbs temp. (I think that I've read here that 5000 is considered "ideal" for temp?)
4. There are 38 choices of shroud styles. THIRTY EIGHT (I can count to 5 on a good day, if I am allowed to use my fingers...)
5. There are 23 choices wiring harness size. (I believe that I'm 9005 for high and low, with no canbus)
6. Headlight sealant appears to be entirely a cosmetic choice, I'd likely just go black unless there's something I'm missing?
7. LED Halos. There are 6 sizes of "pivot switchbacks"??? (I feel like the dumbest guy on the planet, I have no clue...)
8. Anti flicker capacitor. (I don't know what this means and I'm uncertain whether I need this)
9. Shroud adapters: none vs H1 concentric rings
so... I think (maybe?) that I knew the answers to 2 of the 9 questions? If I wanted to duplicate what you have, what would it take?
I welcome any and all advice and/or ideas here. My initial thought was to just change out bulbs and get something serviceable, but what you built is so impressive, that I'd like to duplicate it. I'm looking forward to driving with the kind of light you have in those pictures!
Jared
adventurenali92
Big Bear Lake, ca
I'm in California. I did it. Lol
I had to do the mod when I upgraded my projector lens and starting running the HIDs out of the projectors, to get the lows and highs to function correctly. Have had it in since February here in California and haven’t had any issues with law enforcement yet.
BeenChevy
Minnesota
Been through Many combinations trying to find the best functional setup.
So far I'm sticking with 55w HID in Depot projectors and waterproof relay harness.
Having a tough time getting a good slim set of LED's to fit round Z71 fogs and still aim correct. 55w HID in the fogs kill it but make sure your housings and harness' are waterproof.
corvette744
2004 Z-71
Northern illinois
So your running 55 watt hid bulbs in the depot headlights and they dont melt the housing?
adventurenali92
Big Bear Lake, ca
I have tried several different options now. I went with a Morimoto mini H1 projector lense retrofit last year in a set of anzo u bar headlight housings as they use the same mounting brackets for the projector lense that the OEM housing uses. 35W 5500K HIDs. HD wiring harnesses with ballasts and ignitors. Worked great. But the kit was supposed to Morimoto bulbs and ballasts and they were not. I just upgraded to Morimoto bulbs and ballasts and wiring harnesses and it all works great. Stayed with 35W bulbs but 5000k color temp bulbs and I actually like the output better than the 5500K bulbs I had before.
BeenChevy
Minnesota
Any photo of that setup? 5000k is easier on the eyes I think than anything higher. Went with 4300k on a few of the trucks and ATVs now but pumping em with 55w. All fogs and hi-beam 3000k. Stuck with non-replacing triple projector LED morimotos in the big Yukon and I think those those are 5500k.. maybe 6k.. light output with exception of the hi beam is better than stock HID though
Wings720
What LED’s can you get for the fogs that are plug and play and quality ?
BeenChevy
Minnesota
So many choices out there. As of late last winter a buddy turned me onto a fanless brand called "Alla Lighting". I been all over the spectrum on higher-end and now this $20 brand that kicks @$$. I have 3 sets in a canam I put through snow, mud, and bogwater over the past year. They've been submerged in water and completely caked with snow and ice and no problems. Very impressed to say the least. Ended up ordering new housings for both the tahoe and yukon (circular and square housings) and threw a set of 3000k in. Both have been through maybe 5 car washes and a crap ton of salt and slop without any issues. Might be worth checking out as they're only about $20 and seem indestructible so far.
Conedaddy
