Tonyrodz's Tahoe Build Thread
Scottydoggs
NJ
Get a pic of the wiring and connector. And pull that sensor and inspect it. They welded the bung with the sensor screwed into it, I can see the welding slag on it.
you are so right. both times i had a bung installed they used a old used up o2 to hold the bung when they welded it in. you over heat em nd they dead.
tony you been able to get the tech 2 to connect?
Kept getting this.
Haven't touched it since.
Sam Harris
The fuse is good. Says that intermittently.
I have to tighten up the connections on the cable super tight. Otherwise, I get that all the time with mine.
Maybe try detaching, then reattaching the cable (both ends), and make sure to tighten down the screws as tight as you can (only with your fingers!) you can even wiggle the adapter back and forth a bit while you’re doing this, to get even more force on it.
I tried that a few times. Kept doing it.
Take the tech2 apart, blow on the connectors like a Nintendo 64 and put it back together, try again.
Did that too, took the obd connector off--both pieces, and blew into those. Unscrewed and pulled out the connector from the unit itself, then screwed it back in and hand tightened the hell out of it. I even kept changing the position of the tech 2, just in case there was still a loose connection. Nothing. I don't know what the deal is.
For all you Texas guys.
Check out this item on OfferUp. https://offerup.co/AHfVCnPsFdb
Candielaine
