What is it with these F*KNG valve covers and fill tubes!!??
randeez
south florida
will the oil fill cap go directly into the valvecover without the tube?
if not, holley makes a slim oil fill cap - that does, i cant remember if it has 1 tab or two tabs tho. whatever my stock oil fill cap was i needed the other
89Suburban
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I am not sure @NoReverseYukon says it does, I have not tried it. I will have to remove the cover again to try it for myself. if it does and feels secure I will just use the cap and **** the filler neck. Or JB weld like others here mentioned.
randeez
south florida
stock cap didnt go into the valve cover, holley did
but i cant recall which one had 1 tab or two lol i'll check when i get home
*** looking back thru thread on pt.net i needed a cap with two indents, meaning my stock one only had one indent
wsteele
No I tried a ****** Dorman part and then this GM one: 609729947
GMpartsstore.com lists a different part number than the one you got. They list 12574386. At $42 "on sale" before shipping, I think JB Weld is looking better and better, or as George B suggested, a visit to the local pick and pull yard.
89Suburban
89Suburban
SE PA
Does your tube "tilt" up and out like I am or does it stay tight and flush to the cover?
wsteele
In post #6 the GM part #'s are there with pricing and availability from RA.
Something is really goofy, as the picture for the GM part is the same slot and ramp orientation as the new one he has and should go on, neck facing down and a 180 degree twist to lock in in place. Strange.
randeez
south florida
never had any issues with it.
i dont use the tube anymore but im thinking mine had 2 tabs and the oil fill cap only had one tab, thus i couldnt put it directly into the valve cover.
89Suburban
89Suburban
SE PA
So you just use the Holley cap? Do you have a part # for it?
NoReverseYukon
NE Wisconsin
I deleted my filler neck because it would twist out of it's mount when I was attempting to remove the cap. This was my solution. It is the stock cap and it locks in like it's supposed to.
randeez
south florida
looking at this pic:
you have a single tab, the oem oil fill cap should just go in
my valve cover has 2 tabs, so i needed the holley cap
89Suburban
89Suburban
SE PA
I deleted my filler neck because it would twist out of it's mount when I was attempting to remove the cap. This was my solution. It is the stock cap and it locks in like it's supposed to.View attachment 269446 View attachment 269447
I am going to try this next. If it doesn’t work JB weld it will be. Thanks all. I will keep you updated. Weather here is ****** for the next week or two. Don’t know when I’ll be able to try it.
wjburken
Eastern Iowa
If it makes you feel any better, I went out and was going to pull the full neck off my 2013 to see what it looked like and discovered that the oil fill cap was missing. Not sure what the hell happened there. Fortunately I had a spare in my tool box, but for the life of me, I have no idea where the other one went. I am usually pretty **** about buttoning stuff up and putting the cap back on after watching my brother-in-law sent the hood on his 1990 mustang GT because he left the fill cap on top of the engine and slammed the hood closed. BTW, I couldn’t get the neck to come off easily so I didn’t want to break anything with it being cold so I didn’t get any pictures to compare to yours.
wsteele
Hang in there bud. Our daughter is in Boston, they are getting dumped on as well.
Here in Boise, weird winter. We hiked 7 miles today up on the trails, 48F!
Weird. The one on my 08 Silverado 4.8 just locks into place. Maybe buy a valve cover for a different engine.
Da90
Tulsa, OK
I’m pretty sure I remember seeing elsewhere that the factory cap fits the valve cover.
89Suburban
89Suburban
SE PA
There is a locking tang built into the filler neck base. I would not force it either and risk a piece of it falling into the head. Better to find the time to take the cover off and try to unlock the tab with a pick tool. Even then it can be tough. I have read some posts of some Houdini's able to pick it loose from above.
wwiizz
