Tonyrodz's Tahoe Build Thread
Sam Harris
Take it to the exhaust shop and get a new bung welded on. Better to fix it the right way now, than to fight it again. Also, while you’re there, have them swap the other o2 for a new one. Guessing these are both the same age and if I were a betting man, the lifespan is about the same. I couldn’t imagine it’d cost over $100 to get both bungs replaced. Make sure to use anti seize on the threads. You spent more time trying to guess the popping problem than you did on the o2. If this is the problem, it’ll be worth it to fix it right.
This!
wjburken
Eastern Iowa
Came across this possible solution from Summit. I see similar options on Amazon. Not recommending, just sharing.
https://www.summitracing.com/parts/...eXuwdIMCXOl1K3co9XeKAYJGAtdjKwgxoCmYwQAvD_BwE
