Who needs a high dollar cold air kit
Mudsport96
40.923,-89.488. Illinois
Airaid MIT for a 02 6.0 in a 2500 Sierra on my 06 Tahoe. Stock box and filter.
Outside temp was 38 so barely over a degree difference at 60.
Tonny
Netherlands
Nice job. Yeah you're missing one more mod on the list, the Autocal V3 BBP tune. They can get rid of all the nannies on your truck and also get the best out of the Airaid MIT! Get a octane tune etc etc. :):):)
Tonny
Netherlands
Do you have some photo's from different angles of the MIT installed on the Tahoe? Really keen to see that!! You run the 200-912?
Mudsport96
Mudsport96
Yeah ive talked to them, but i prefer to do a in person tune. My tahoe has the virtual flex sensor that reads tje O2 sensors after a fill up then adjusts timing and fuel. And ive talked to BB and several other companies including 2 local ones, most want to either disable the flex or install and actual ethanol sensor and go to an older OS. BB says they can work with it, but id like to do it in person.
Tonny
Netherlands
I can try to get some later this week. I work a different schedule than my wife so i dont see the tahoe much lol
Cool mate, would be nice. Because the 200-912 is the mech-fan version, do you have a mech fan or e-fan?
I understand you. I first wanted in person as well. I went to a tuner who could do basicly everything that BBP can. But the difference is, BBP has sooo much experience. They really know what your stock motor and gearbox can handle, and also tune mods with it. I first really wanted a in person tune also, but this forum convinced me to go with BBP.
Why would they want to do that? So that they will tune the computer on one sort of fuel?
Mudsport96
Mudsport96
Yes its the 200-912. No mine is the efan setup, but for the price of free i wasnt going to pass up a airaid pipe.
I guess its because instead of an actual sensor reading ethanol content, the computer looks for a lean condition at the oxygen sensor. It then ASSUMES that you are running a higher ethanol level fuel so it adds timing and fuel. But if its just a gasket leak causing the lean condition, you get more timing without the added octane. So you get into danger of detonation and fragging a piston. So if you already have higher timing from a tune... you add more for what it thinks is e85 and now youre really at risk of killing the engine
Tonny
Netherlands
I can imagine haha, if something like that would pass by in the Netherlands, I would buy it, although I'm going e-fan! But they say the working of 200-912 and 200-919 are the same, but the 912 is build to clear the shroud and fan. I'm just wondering if they are really identical in gains, why would you otherwise make a different one for the mech-fan and one for the e-fan.
Anyway, I'm going e-fan first before doing Airaid MIT I just decided ;)
I also asked that question to @BlackBearPerf about a certain octane tune. Why that is necessary because the Chevy computer already does that? We only have 95 or 98 octane for example. I did a read-out at my local tuner also, he said the computer is noticing which fuel you use and will change according to that. So I'm wondering why everybody does the octane tune also?
EDIT: And I can't find out if the first gen 5.3 Vortec engines have gaskets and hoses that can handle ethanol. Since our fuel changed in 2019 in the Netherlands, there is 10% ethanol in Euro 95. I only tank Euro 98 now because that has E5 but most of the time 0% ethanol in it. We've a website to see if your car can handle it, but the American cars are not on that list... in late 2002 the flex fuel models came, so it's logical they can handle ethanol, but what about the first 5.3 vortec engines..... I think for the LS1 for example, 98 is now adviced for that car here.
EDIT2: For example BMW e36/e46 M3 should tank 98 fuel only, because those are race engines.
Mudsport96
Mudsport96
European octane numbers are different than us numbers. But its because of the different testing procedures. European 98 octane is equivalent to the US 91. Heres a link to read
https://www.etuners.gr/fuel/
Mudsport96
Mudsport96
Ah ok.
Well its because the factory is so careful with how they setup the original tune. If an engine can make 350 horsepower and lasts 100,000 miles (160,000km), but can be detuned to 275 horsepower and make 200000 miles (320,000km) the factory will go that route. Because less power will be easier on the transmission and other driveline parts. And that will hopefully get the vehicle out of the warranty period before any major issues so that they dont have to cover them.
Tonny
Netherlands
Ah ok.
Mua partly true but that is not the part of the tune I mean. I mean the ''octane'' tune. If the PCM sees for itself what fuel you use, why would you tune it to a certain octane tune? @BlackBearPerf
The other stuff I know, but also A lot has to do with the environment and exhaust fumes and regulations. In the 60/70, a 350 made more horses then a 1996 350 for example.. And I know the restrictions from factory and are very excited for the BBP engine/gearbox tune, but I want to know where the octane tune is good for?!
Mudsport96
Mudsport96
From what i understand it is not a tune that "sees" the octane you are using. It is a tune that REQUIRES at minimum octane or there will be detonation/pre-ignition.
Example, you can go walk by a beehive in shorts and a t shirt and they will leave you alone for the most part. Thats like a stock tune and normal clothes.
But want to shake the hive for honey. ( High performance tune) You should have on a bee proof suit ( higher octane)
Hope that makes sense
Tonny
Netherlands
It makes a little sense. I think I must conclude it is better to tune it to the certain fuel you use, so it's more efficient, then when you let the computer decide...?
Mudsport96
Mudsport96
Sort of yes. Its more that the tune will dictate the minimum octane you can use. The computer doesnt actually "see" the octane, it "hears" it.
In the US we generally have 87 89 91 93 octane gasoline. A stock tahie will run fine on any one of those the ignition timing is low so it doesnt care. If you get a tune for say 89, with a little more aggressive timing you may get spark knock. If that happens, the knock sensor "hears" the noise and reduces timing and thus reduces power.
Now say you go all out and get a tune for 93 octane. You had better run 93 the timing will be pretty aggressive so you may get away with 91 but 87 would probably cause issues if you towed or hotrodded the vehicle. As the knock sensor may not catch the knock right away and pull timing too slowly.
The factory tune can adjust some, but when you get a tune, you're kinda saying this is the octane i plan to always run, Tune for that octane.
Tonny
Netherlands
Thanks for taking the time to explain :) And then the result will be more power because the computer is reconfigured to the fuel you're using all the time?
varminpoolteam
