Unsure if I want Tahoe with AFM
Diezel Raccoon
So I have been looking into getting a Chevy Tahoe. I have always been found of the 2nd gen style and wanted to get one in year range 2004-2006. I am very familiar with the 5.3 engines in those and how bulletproof they are. On the flip side the mpg on them is not as good as the newer ones. I do like the look of the 3rd gen and especially like the better mpg they get but I have had a lot of people tell me to avoid them because of the active fuel management system and how it causes issues down the road such as failed lifters. I had one friend tell me the issues with the AFM was resolved in the 2010 models and up.
If someone can give me some feedback on this I would greatly appreciate it. Thanks
wjburken
Eastern Iowa
Welcome to the forum from Iowa.
If you can avoid AFM, that is preferable. If you need to get one, get a newer model (2013 or 2014). If you can find a ‘07 or ‘08 and possibly ‘09 Yukon Denali with the 6.2, they don’t have it.
Worst case if you get one with AFM is you can do a tune delete where it turns it off or a full delete where you remove the AFM parts altogether and get a tune.
Or, you can do what I’m doing. Change the oil regularly and hope it doesn’t act up.
wsteele
I own a 2007 Yukon 5.3L Flex, AFM. My pistons and rings were replaced at 95K due to the valve cover and PCV issue they did fix in later models of that gen. Thankfully, I haven’t had any lifter issues (yet?), just installed a Range Tech ODB plug in that forces V8 mode all the time. Hopefully I can avoid AFM induced lifter issues with this mod. Only time will tell. Simpler is usually better. :)
PS - I love this truck so much, in the end, whatever it takes to keep it on the road and looking like new, I do. I can’t tell you how many hours, days and weeks I have spent looking for what might strike my fancy to replace it, they always come up short on what I already own.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon. I hear lots of negatives here about the AFM engines. Like @wjburken said, get the year you want with the 6.2 engine and worries are gone. I do love my 2005 Z71 though.
Bill 1960
Testing the Limits
If you read forums, cylinder deactivation is usually seen as the work of satan. That goes across every brand of vehicle. And it IS one more thing in a vehicle that can, and does, fail.
My view, is it brings certain benefits -fuel economy- at a certain cost -more potential failures. Just like many things: power windows and locks, automatic transmission, power steering, and on and on.
I neither see it as a reason to buy, or a reason NOT to buy a vehicle I otherwise want. It’s easy enough to tune it off or to delete it mechanically if that’ll bring you peace of mind.
Welcome to the Forum from NH.
You have already received some great comments and advice from the folks here.
wsteele
Every professional mechanic I've ever spoken to tells me the same thing: change your oil regularly and AFM failure is not an issue (extremely rare).
That sounds pretty accurate to me.
I am certainly no expert on the subject, but looking at my ownership experience with my 2007 5.3L Flex/AFM Yukon, I think maybe some percentage of the increased failure rate in the AFM lifter area might be attributable to the old valve cover PCV design. In my car, this defective venting design promoted excessive oil being burned in the combustion chamber causing stuck rings and a downward spiral of oil consumption.
Even in cars regularly serviced, it may have lead to oil starvation or contamination between regular changes that may have gone unnoticed by customers who never checked oil levels between changes. In my engine's case, it was using a LOT of oil between changes. Someone who didn't check their oil level between changes might have thought everything was working fine when they were adding additional stress to lifters which don't hold up particularly well to stress, hence lifter failures that would never had happened had the valve cover not promoted excessive oil consumption.
If the above theory is correct, cars that came new with the updated valve cover (I understand sometime in the 2010-2011 timeframe), that have been regularly serviced, might show zero difference in lifter failure in AFM equipped cars.
adventurenali92
Big Bear Lake, ca
Except that this isn’t correct. 2007 and 2008 6.2s had the AFM components in the engine but were not activated the ECM software programming.
The ONLY 6.2 engine that HAD NO AFM system was the L9H 6.2 for 2009.
Everything from 2010 forward in a 6.2 had the AFM system and it’s active in the ECM software programming. Along with all 5.3 V8s from 2007-current.
See, I learn something new every day. I was going off of what @wjburken was saying and I bet he knows what you just said but was generalizing. He said 2007 and 2008 knowing that they were not activated with the ECM software and he said 2009 Denali that did not have it at all. I have no experience with that engine because I was out of the shops by then and did not know the details you just shared. My bad.
adventurenali92
Big Bear Lake, ca
All good :D
donjetman
I see 2 errors with what is being presented in this thread:
1) There is a more recent version of this TSB technical service bulletin. I've been posting the latest version in various threads here for 2 yrs. TSB 10-06-01-008M:
https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
2) The factory valley cover (VLOM/hardware) that came on my 07 Denali 6.2 L92 does NOT have any ridges/oil passages necessary for AFM activation. So regardless of software or any other hardware, it is impossible for AFM to activate. I believe the following is true for the 07-08 6.2 Here is a note from the mx log book that I keep:
The L92 actually had a first and second design.
The first design, built prior to April 1, 2006 contained AFM components, but were left disconnected from the ECM.
The second design eliminated the AFM components altogether.
wsteele
https://f01.justanswer.com/ebrock63/cec66346-04c1-48e0-98a6-74c35af2c84e_2014+Engine+-+Oil+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
I posted the down rev TSB -F versus -M. Sorry I missed your previous posting with the newer rev bulletin.
I read through the bulletin in your link but was unsure what the difference is in the latest guidance, versus the link I posted to the down rev TSB.
Is it related to the guidance of how techs should proceed on iron versus alu block engines?
EvergreenZ71
Firefighter EMT/First Responder
Washington
So not to hijack, but I assume then that the only 6.2l Tahoe in that body style just happened to avoid the AFM? Nice
TahoeAgain
I bought a 2008 Tahoe in late 2008. It had 21,000 miles when I bought it. Sold it last year with 131,000+ miles on it. NEVER had a problem with the AFM. Only major thing I had to do was replace the gears at the rear axle (under warranty thank goodness) the second year I owned it. Great vehicle.
PLohr
We have a 2008 Denali without AFM. I rebuilt the engine...it did not have AFM components.
JasonW4141
