Bleeding brakes, sucking air from Master cylinder?
Jason in DLH
Cheeseburger and Fries
MN
Yes pedal to the floor. Bad?[emoji51]
Yeah...I’ve read that you can blow a seal and/or damage the MC by doing this.
Here’s someone’s take on it..
Not only is it not-uncommon to blow lines while bleeding brakes, it's also fairly common to wreck a master cylinder when you full stroke it if it has nasty fluid in it. Rust can build up in the bore in the normally never used part of the stroke, then when bleeding the brakes you scrape the seal over the rust and now you get a sinking pedal.
O
optimusprime
So it could be a blown seal within the MC?
Jason in DLH
MN
Hopefully someone else can chime in here, because I’m all out of ideas!
Im really hoping a line didn’t bust!
O
optimusprime
Well on the plus side, there are zero leaks anywhere so probably not a line
O
optimusprime
Im a total newb at this abs stuff. Is replacing the MC a nightmare job?
Jason in DLH
MN
I’m not exactly sure what happens when the seal breaks (never had it happen), so I don’t know what to look for there. Never had a line bust on me either.
Hopefully someone with experience to the aforementioned shows up to the party!
Jason in DLH
MN
Don’t quote me on this for I’ve never change a MC, but I don’t believe it is difficult. Just get rid of all the fluid. Change out the MC. Add fluid and re-bleed. But, this is where you would definitely need a scan tool that can perform an ABS bleed.
