optimusprime
- Joined
- Jul 15, 2016
- Posts
- 104
- Reaction score
- 25
Just finished my brakes and rotors on my 08 Yukon XL Denali. I bled the back two calipers following the recommended order. Flushed the lines and got all the gunk out until fresh fluid was flowing. No issues with the rear. Filled the MC reservoir each time and kept it full. Then I did my front brakes and rotors. I had to depress the pistons to install the new pads. Boots were in fine condition. Put it all back together and compressed the piston by slowly pressing the brake. Got a good firm feel on my brakes. Began bleeding the front pass side and everything was going fine for about 5 pumps and then it started blasting air. Now I’m at the point where no fluid or very little at most is coming out of the blessed and there is no pedal pressure. MC is full but is making a gasping or sucking sound like a straw at the bottom of a glass when the pedal is released. I can’t figure out what happened. I am using the hose to bleeder with the hose submerged in fluid. There is no air coming in around the bleeder. Please help.
