2006 gmc yukon xl slt option 2 electrical
Woodblocker55
Woodblocker55
Ok I got new throttle body with module . Coming I see how to install it .. but is there a learning cycle I have to do ..like a drive cycle then reset check engine light. ??? Is that all ?
Sent from my LGL722DL using Tapatalk
mwilson62000
I’ve never found an official relearn procedure. I would disconnect negative battery cable, then replace throttle body. Once you hook everything back up and start it, idle could be a little off until it learns a bit. Just drive it.
Super Moderator
Elev 5,280
Doesn't the Tech 2 have an idle relearn for the DBW TB?
mwilson62000
I thought it did too, but when I did mine, my neighbor brought home his tech2 and and we couldn’t find a relearn, just where we could show parameters of the movement of the throttle blade.
Super Moderator
Elev 5,280
Curious. I'll have to pick through my menus again since I'm not sure if it's there.
Woodblocker55
Woodblocker55
Here is the one thats on 2006 yukon xl 5.3L. I checked like 4 places for new GM number and it matched Rock Auto number . So hope it's right one . Is it same throttle body as 6.0 it said on carid.com.[emoji849][emoji849]67e30fa08c2d2cbf294881fd386130f9.jpg
Woodblocker55
Woodblocker55
2006 gmc yukon xl slt 185,000 miles I got the code P2108 and U0107 .. I bought a new throttle body with controller. But I just came across this on the internet.you think it's possible that the guy that owned it before never updated it from 2006 on the PCM.
It trip these codes when I use the remote start. So it trip those codes when not in motion. Any ideas??bf9801a6574735c97ab3b1ade5783e6b.png
Woodblocker55
Woodblocker55
Is there a way to tell if they updated the PCM in 2006 ?? With scanner ?
