St. Louis
Got the other head cleaned up and assembled.
I did a waaay better job on this one.
Now i think i better redo the other head so i don't have an imbalance or something anoying.
:D
And i have one head bolted down.
Used tie-down straps to pull the exhaust manifold out of the way to get a torque wrench in there.
The degrees thing...
Stretching the bolt should make up for minor imperfections i hope... :rolleyes:
And i miss my hoe.
It's cold out, and our other cars don't warm our butts.
:angels2:
Merry Christmas all! :cheers:
Do these motors have torque to yield head bolts?
Any motors that I've had the heads off I've replaced the bolts with either ARP bolts or studs if I plan on running boost. They're reusable
:D
And i miss my hoe.
:angels2:
Good luck. Hope you don’t get a leak.
Just Fishing
Can't fix stupid
Utah
Crossing my fingers lol.
I didn't go too crazy with the head cleanup, mostly focused on cleaning and preventing carbon from sticking.
Before installing, i did a slightly better job around the spark plug area.
I didn't grab a picture tho....
Getting motivated for more hoe work...
:Caffeine::Caffeine::Caffeine:
Um...By look at the second photo I think you may have a problem with your suspension. Or you could just have a sick set of air bags installed on er’. Lookin good!
Has a nice stance, looks good. :cheers:
Nice. Now id end up forgetting to leave it aired up and come out one day to it frozen to the ground :eek: :rofl:
...Y'all do know this is a photochop, right? A buddy sent me a link to an app: "Suspension Master"
Sometimes, I wish it really was 'bagged.
Just Fishing
Can't fix stupid
Utah
My engine oil priming setup, hopefully it works when it comes time...
Bought the little adapter for something like $8 on amazon.
And the heads are on, just the passenger side has not yet been fully torqued... in a few minutes the fun begins!
Just Fishing
Can't fix stupid
Utah
other head is on!
did a check with a digital gauge, seems to be about 75 ft lbs for the head bolts
So i gave every one a once over for good measure... the back ones were the hardest to get a good angle gauge on, so it's a nice little piece of mind.
Now i'm going to tackle the front axle install...
yay my favorite part...
:yaoface2:
:win:
:emotions122:
PG01
Up here to the right
Ls 6 springs, new guides/ seals. Installed on 5.3 ls flex. Waiting for cam and trunnion kit. Noticed on springs they have white stripe painted on have no idea what that is for. I’ll have plenty to do when cam shows.
Same white stripe on my garage door springs.... so you know how many turns for tension......
:yaoface2:
JamesinAbilene
