Yukon XL - Remote start = Alarm?
nokuy
Petersburg, MI
2016 Yukon XL alarm goes off (sounds) after using remote start and vehicle has turned off after 10 minutes. Neighbors I’m sure don’t appreciate this. Is there a way to stop this from happening?
Doesn't sound right, might need a trip to the dealer or get their tools and diagnose and fix it yourself.
Tahoe14
Central Fl
Just read about this on the other truck forum. Check the rear defrost wire to see if it came unplugged or not seated all the way. That was the fix on the other forum. It is tied into the alarm system. Good luck.
Thrust
ICT
Battery ok? When our Yukon's battery was on its last leg the remote start would cause the alarm to go off.
N
nokuy
Petersburg, MI
Picking up Yukon on Saturday with the new transmission now installed. I’ll check the rear defroster as well as battery. Thanks for the suggestions.
Thrust
ICT
Any updates? Still have the issue?
Tonyv__
Bucks county PA
If you remote start then unlock the truck. You’re alarm shouldn’t go off. I been doing this for a while.
I’ve researched myself. It’s either dying battery or defrost wire on the back window for the most part. I know my defrost tab was broken off. But I glued it with one of them cheap kits from autozone and I don’t think I did it right.
Koganinja
Buy a scanner or get it scanned at dealership. I was having issues and it ended up being the hood latch sensor. It was sitting too low and triggering the alarm at random. It could be so many things though. Wild goose chase without a scan. Old post but posting for others that may be searching for answers.
albac
