Hi,
Working on fixing a few things on my 2010 Tahoe, to include passenger side mirror. The tilt and folding stopped working. I took everything apart. Fixed the tilt issue by replacing a motor inside mirror adjustment panel. Took the folding motor apart and as with many had a broken spur gear. I replaced with the brass one. Now, put everything together (few tutorials online) and while Gruven Parts have a pretty good tutorial, the entire motor assembly fits together like a lego (only one way). The problem is the mirror is very hard to fold even by hand, which causing the motor to work very hard and it does not always fold the mirror. I took it as far as shaving the collet's protrusions as mentioned by Gruven Parts, but did not solve my issue and perhaps I shouldn't have shave it. Issue one: Since owning this vehicle the passenger side mirror always folded-in more than the driver side until it broke. Now testing it on my bench, I can see it has a wide movement range is it spins on Mirror Base (see #1 on attached pic). Can anyone please confirm if their passenger side mirror folds-in more than driver side? It will help me troubleshoot my hard to fold issue. Issue two: I am pretty sure the reason it is very hard to fold the mirror in is because of steeper indentation angle in the collet as Large Gear rotates out of it (see #2 on attached pic). I understand this is likely done for the force of wind while driving does not fold the mirror. Essentially the Large Gear is held inside in the collet by pressure spring and in order to fold the mirror, the motor must force the Large Gear out of the collet while compressing the spring. I think I can fix it by ether the cutting the spring shorter, thus decreasing the pressure and therefore allowing the motor to more easily snap the gear out of the collet or make the angle on the collet more gradual (#2 on the attached). However, I don't want to do all that before ensuring that I assembled everything properly. I have some concerns as don't understand why the mirror was always folding in more than the driver and perhaps at some point it was replaced by a previous owner with improper folding assembly thus causing all this headache for me. Anyone has any tips? TIA.
Edit: I am starting to think the issue with with the collet. Since I shaved it, it now sits lower in the assembly causing main gear to rub against the mirror base. Well **** me and those guys at gruven parts for ****** tips if this ends up being the true.
