NAV won't tilt!
big wheels
Just purchased a 2011 ltz with 2000 nav disk. went to replace but the screen won't tilt and wanted to see if anyone had a fix before I spent more money at the dealer.
never tried it but you could use a pc and make a image of the disc on a thumb drive and see if it will do the update that way. I figure it's a 50/50 chance. let us know if that works.
B
big wheels
Yep! Watched that one. My screen doesn't respond when I hit the change button. It just reverts back to the previous screen. No noise, no vibration, just doesn't respond.
St. Louis
Don't think that'll work, the 2011 has no hard drive and needs the disc installed to read the maps.
petethepug
Michael
SoCal
This will dial in a 2011-14 Escalade SuperNav CF card update procedure.
https://www.cadillacforums.com/threads/nav-cf-card-location.249868/
B
big wheels
Thanks, what I ended up doing was to unplug the radio fuse 43 and 42 for ten seconds and re install, worked like a charm. Found the fix on a corvette form. Looks like they have the same problem.
Drewphil
