Lights opinions wanted
dub02gpgt
dub
WI
bluebear15
wisconsin
another member bought headlights from ebay recently and hated them within the first week. they fogged up and got moister inside them.
one option is to stick with TYC headlights which are very good and recommended by everyone or you could get those headlights and then seal them up before installing them.
Arctic-Rodz
RGV Texas
id go with the smoked ones. Im looking to upgrade my headlights, bumper and corner lenses too. I found some with LED bumper lights that look cool on ebay too. Does chevy and GMC lights from the same year fit each other?
D
dub02gpgt
dub
WI
are there any reasons why the smoke one's would look bad with HID's? Does anyone have pics of the smoked ones installed? I assume your talking about running a bead of clear silicone around the crack where the lens meets the back part of the headllight correct?
val620
Bay area
$109
The $109 ones look good and the seller has no negative feedback id go with those
bluebear15
wisconsin
correct. a bead of silicone around the crack where it seals together.
those smoked ones dont look that bad for filtering light but i've heard some people say that anything that hinders the light output, such as the smoked lenses, gives crappy light output that you cant see 10 feet in front of you (even with HIDs)
also for $110 you can get a set of TYC headlights from streetbeatcustoms.com (imo the better buy) you can buy a set of parking lights on ebay cheap. they're all the same.
D
dub02gpgt
dub
WI
Ill have to do a little more digging and ask some questions, I thought the lens itself was clear and the chrome portion of the housing was smoked instead of standard chrome. I would think if that's true there would be no difference in light output? I'm not opposed to the clear ones, but that's all you ever see and I wanted it to look different. By the way sweet sig pic! Where in WI are you from?
wicked2000
El paso TX
I have black ones and they look good just cant see very well if I dont use the fog lights.
bluebear15
wisconsin
having the chrome reflector section smoked is even worse. this does not reflect the light properly like the chrome does. the best is to have chrome reflector and clear lens. i'm not sure how badly it will affect the light out put tho but it will decrease it.
thanks! i'm bout 30min west of milwaukee
fyremanpat
Fyremanpat
TYC elegante...ef the rest..its worth it trust me..Ive had at least 4 pairs of headlights that leaked off ebay
blackcoffee
O.G. Black.
Or you could do like this guy did. I Think he's got the right idea.
haks310
Got LEDs?
SoCal
Neither has a glare shield so light scatter will be an issue once you go with HIDs.
You will need to silicone the corners, those things will take on water like no other.
I really don't see a problem with the smoked set, if the headlights are DOT/SAE approved then light output shouldn't be an issue.
Parking lights will collect moisture, it is normal. They have a drain hole at the bottom for this reason.
And yes, Tahoe and Yukon headlights are interchangeable. The corners are not.
AdrienR
