So you’re saying our trucks can be started with a bit of bailing wire? I don’t think so. You must have had all the tumblers except one stuck open.
My 02 doesn’t have a security key. I still highly doubt you can turn the cylinder with a piece of twisted wire unless that cylinder is defective. What kind of a cylinder would be that easy to defeat? Go try it now that it’s in and functioning normally and report back.No...they were all closed. I’m sure of that. Yukon’s have a security feature that requires the key to be close to the ignition to be able to start. When I had the cylinder out I tried starting it with a screw driver and I couldn’t unless I put the key right up against the security device. Don’t worry...nobody will be able to steal your truck by this method! I just needed to be able to push all the tumblers to unlock it so I could remove it to correct the problem.
Well...maybe Just Fishing would be better at this than I as I gave it a try again tonight and came close, but failed. Here’s what the cylinder looks like without the key in it:I think your key had released the tumblers except maybe one and they were still in the released position due to you turning the cylinder partially and the wire pushed up on the last one. Which would make sense since you read one number wrong so one tumbler wasn’t set right and the key wouldn’t work on that one.Well...maybe Just Fishing would be better at this than I as I gave it a try again tonight and came close, but failed. Here’s what the cylinder looks like without the key in it:
The left side is up and locked. Here’s it with the key in (left side goes flush thereby unlocking it):
And here’s my failed attempt:
I got close, but it didn’t work. I wish I had my original tie wire to try again as I had to cut a couple new pieces tonight.
I must have gotten really lucky (this is as close to winning the lottery as I’ll get) or like you guys said something must of been wrong so that I could turn it in order to remove it. When I originally got the cylinder stuck in the steering column my key wouldn’t turn the cylinder either way.
I dunno...time to play video games...
