2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I forgot right now It has factory spindles But i have a set of drop spindles on the shelf. Not sure how much that would effect shock length and I do NOT want to go any lower. I guess I have more stuff to research.
randeez
south florida
Looks like ride height is right at 14" from the top stud to the bottom eye bolt. The eye bolt brackets add 1" at the top and probably around .5" at the bottom but I also have a set of the stud top adapters which eliminate that 1" at the top if need be. I also have a set of 8" 1,000lb springs but I have no idea what size spring is needed that will require some more research.
Gonna PM you about making a deal.
Also I just measure exhaust area to play with and I have right at 18" from drive shaft to frame and can fit a muffler with a case that is 24" long, lastly from body to bottom of frame rail is 9". I looked on magnaflows website and they have a 7x7x24" round, chambered but straight through muffler that is under $100 and 2 should fit nicely without hanging below the frame.
i just wrote you a novel.... to not clutter this well organized thread up
randeez
south florida
depends on if the shock gets you any drop at all, you can preload the shock to bring it back up if you want to
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Back to the more important exhaust while me and "might as well keep upgrading Randy" sort out coilover stuff.
So current thoughts and I'd like to order something by tomorrow morning so it shows up this week.
1: Dual Magnaflow #13742 7" round 24" case chambered but straight though mufflers.
2: Dual Magnaflow #12279 5x8x24" straight through
3: Dual AP https://www.amazon.com/AP-Exhaust-Products-XS2579-Muffler/dp/B004A5OBVA But they say 11.5" tall so thats too far for me.
Who thinks what will be quieter?
Those AP brand are straight through design with sound absorption packing correct? Basically knockoff magnaflows?
Yaaaaas. Best I can tell, the only difference is no "MF" embossed on the body and the overall width and height is a little different (probably for copyright purposes). The length is the same, though. Oh, and 1/2 to 1/3 the price. Hell, their part numbers are almost identical. They just omitted a number.
My thoughts are, since you're only passing half as much sound through each muffler as I and most anyone else is, you can get away with about half as much muffler on each circuit. Since you have to stand yours up vertically, you have to pay extra attention to the width. Shop here for some mufflers then search Amazon or ebay for the part numbers: https://issuu.com/apexhaust/docs/xlerator_performance_exhaust_7a048979fdf974
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I was thinking the opposite of your theory. I was guessing that since I have twice the area for the sound and air to escape from that I would need either the same amount of mufflers as someone with a single exhaust or possibly more because it would be like running a 4cylinder on a single 3" which usually shrieks. I like those AP mufflers they just don't have anything that will use all my provided space. I remeasured last night for about the 11hundreth time and I think I can actually squeeze 30" off muffler case length. I will have to chop the inlet and outlet down to almost nothing and welding it will suck but I'm gonna try doing it myself. My neighbor has a 4 post lift so I'll haul my little Hobart over there Friday and give it a shot. I am going to call Magnaflow today and ask about the 7x7x30" round 3 chambered/straight-through muffler. That gives me the most possible area of muffling, but I'm confused as to why it says straight through but also 3 chambered. I found 1 picture from amazon that shows that it is indeed straight through but I want to know why they list it as chambered because I think a key to cutting resonance is having some chambers for the sound waves to reflect off of. Also still probably going to cut the unknown cats out because I'm not sure if they are real cats or just shells to fake out the Texas emissions losers, either way, they are half the size of the vibrant ultra flows which I will replace them with.
Also, another reason I'm a little skeptical of the AP mufflers is I can't seem to find anywhere that shows exactly what they are packed with, and this truck will likely see boost of some flavor in the next year or two. I've had good luck with the magnaflows and vibrant not blowing/burning the packing out. Not sure how the APs would fare under high EGTs.
I can't answer about the chambered discrepancy. Unless there's an area in it that doesn't have packing behind the perforated core to let sound bounce around in there?
I've never given the packing of the AP a thought. I just did a little digging and found a review on Summit where a buyer said it was fiberglass. I did a one-year comparison video for the 18" and couldn't tell a difference. But, that's with the chilly ~500-degree exhaust from an NA 5.3.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Fiberglass isn't bad Magnaflow and Vibrant both use it but they layer stainless steel mesh first to take the majority of the heat while also absorbing some sound. The AP would probably survive just fine unless it was very close to the downpipe on a turbo or the collectors on a blown setup.
I am on hold with Magnafuxk now.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Wow the customer service guy told me the giant 7x7x30 will be louder than my current muffler. He said it is not straight through there is no packing whatsoever its just 3 chambers and will be raspy and pop like crazy. I kinda don't believe him, that picture is directly from a verified purchaser and it is very obviously straight through. However, some other reviews I've found are very conflicting on sound level and many people say its ridiculously loud.
He said the quietest straight through muffler is 12589 which is the same thing I have now but single I/O with double the packing.
About to call flopro.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well before I could dial the Flopro number they responded to the email I sent Saturday. I asked about the difference between the three 9x12x24 models they have.
Their response:
"Howdy, the real only difference the chamber size inside and the size of the pass through holes in the chambers. The 2506 and 2505 will flow slightly more than the 2500. The 2506 outlets are the same as the 2500 which flow slightly more on one bank than the other. The 2505 does not have the offset orientation of the outlets and will flow the same for both side."
I think I'm leaning towards their 2505 now as the 2500 was almost perfect it was just lacking a hint of sound and I didn't like how it necked down. Plus I think I can fit the ultra quiets in if need be.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yes I know I'm talking to myself at this point.
I called Flopro and the same guy that emailed me picked up the phone (He sounds like a Canadian, but I won't hold it against him). He was so much more knowledgable and friendly than the Magnaflow guy I talked to him for about 10 minutes. The 2505 not only stays true to 3" all the way through, but it also has larger perforations in the baffle tubes. Another major difference contrary to the website which he told me is wrong the inlet and outlet are both in the same spot front to back. The other models 2500/2506 have one of the outlets offset which forces the majority of the exhaust out a single outlet until the restriction becomes too much and then forces it out both sides. The 2505 does not have that restriction. He said they sell a ton of the big oval mufflers for guys that get sick of trying to find another brand that doesn't kill them once they do headers and delete cats.
I just ordered a 2505 and it should be here Friday just in time to use my neighbors lift and try to get this thing installed myself.
The 12589 is what is widely known as the "stock but slightly meatier tone" replacement for our rigs. It matches the factory center in/offset out configuration. The XS2579 I have is the clone of the MF 12579. Same muffler, but with a center in/center out configuration. I'd have to agree with the MF rep. I'd say my Tahoe, with cats in place, would sound almost 100% stock with the 12589 or 12579 (or the AP clones).
I kinda get what you're saying with "I was guessing that since I have twice the area for the sound and air to escape from that I would need either the same amount of mufflers as someone with a single exhaust or possibly more because it would be like running a 4cylinder on a single 3" which usually shrieks". But, most 4-cylinders would be 1.x - 2.5ish liters. Looking at yours like two 4-cylinders, they'd each be 3 liters, which is about what many small V-6s are. Although oversized unless it's boosted, the V-6 seems to do a little better than the 4-cylinder with the 3" exhaust. Yours, having an extra cylinder in that 3 liters of displacement, would produce a lower-pitched note which is easier to muffle. Also, you should have an H-pipe ahead of the mufflers. This would balance the sound and the connecting pipe, being perpendicular to the flow, would act a little as a muffler itself with some minor wave manipulation. An X-pipe would balance sound as well, but it's geared more towards and wouldn't manipulate the wave any. Well, aside from any that may collide in the X.
I though you wanted a straight-through style muffler? Aren't these "turbo" style? That would explain the need for the larger perforations.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
That's exactly what I was getting at with the 4cylinder talk. Thats a good point that its a deeper tone that should be easier to muffler.
I also agree a 12589 with everything else stock would likely sound close to stock but as soon as other restrictions are removed its far to loud for me at least.
I do not and really don't have a way to do an H pipe myself but It has been a thought after watching the 6 different "Engine Masters" episodes on muffler differences and seeing that an H/X pipe makes a significant difference at lower RPM.
Also yes I did/do want straight through but it is somewhat unobtainable with the low sound level I'm after. At least with the space provided and the amount of money I'm willing to throw at it. Also like we agreed earlier dual 3" is way more than this motor can fill and cause a restriction with. For the future when it may see boost engine masters showed that the boost did not care about the muffler and still made amazing power.
Lastly speaking to the flopro rep made me really want to get another 2505 and cut it open. He said they are significantly more free flowing compared to the 2500 and 2506.
...For the future when it may see boost engine masters showed that the boost did not care about the muffler and still made amazing power.
Love me some Engine Masters.
Any thoughts on how you would you boost it? Turbo? That alone would make for a great muffler so it'd be extra quiet if you can manage to get it where you want it now, NA.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
It's really a toss up and I have 3 ideas.
1: Basic T6 Trick turbo kit nothing crazy let him spec a turbo that would work well for towing and leave it on low boost because this motor has unknown miles and gen 3 rods.
2: Put turbo on my Silverado and put the wonderful torque monster TVS1900 on the Tahoe but keep it running 6 rid belt drive and around 8-10psi. Not max effort like it is now.
3: Torqstorm really looks great makes plenty of power for me has amazing customer service and is cheap!!!!!!
But I think a turbo is what I lean towards now because quiet, efficient and makes cool noises.
My thoughts:
You already have a blower, so switch it up and go turbo.
The Silverado is a 4x4 so the instant torque from the blower makes sense here. And it's already installed.
The turbo on the Tahoe makes more sense because it's your daily so you can hear them cool noises err'day and the slight bit of lag might help not blow the tires off so easily since it only has two wheels pushing it.
...Never heard of Torqstorm. Googling...
Buford bubba
