George B
¯\_(ツ)_/¯
Thought I would start up a separate thread so others might find this once I get it figured out. I started posting in our What did you do to your NNBS... thread but will continue here:
Heard a new rattle from the passenger rear. Thought maybe since I switched from using the AC to heating it was a flap in the rear heater. Nope, every mode possible and still there. Decided to have the wife drive while I rode in the back. Coming from what sounds like the wheel well. No change in the sound with the cup holders pulled so I don’t think its inside. Decided to pull the liner down and have a look. Thought maybe a critter put a nut up there or something. Was inconclusive so I put it all back together. Will see if it goes away.
Nope. Still there. Of course I can't duplicate it parked. needs to be moving and sounds like it happens during body flex. Could it be a body mount?
Unlikely a body mount. Maybe put it on jack stands under the rear axles, and have somebody bounce up and down on the rear bumper while you listen. Something obviously came loose.
Unfortunately it doesn't seem related to suspension movement like a bad bushing or sway bar link would. It is related more to bumps and or body sway. For instance, I cross a speed bump on an angle so it's a double bump/sway and I hear it for each wheel bump but I can't get it do it when I rock the truck from standing on the running board. It is a sound similar to if a ratchet strap tail was smacking the body.
Make sure your air deflector under your front bumper isn’t flopping around.
The sound is coming from what seems like the left rear wheel well. I was riding back there last night while the wife drove. Thought for sure I would find a walnut above the wheel well liner.... Nope.
Was chasing my rattle in the rear. Took the interior panels off the quarter and rode around. It is not inside the cabin. I did figure out how to duplicate the noise by pounding my knee on the floor right between the rear brackets for the third row seat on that side. The problem is that neither the wife of my son can make it do it. Only me and I can’t be under it at the same time.
Dropped the spare down looking for that stupid noise. I thought maybe since I had it down for my axle lube change that I wasn’t seated correctly. Nope, not it. I will have to take the liner out of that wheel well and find some help that can search while I make the noise happen. WTF!
Turn up the radio. Solves a lot of problems.
Did that on my ride in this morning.
My concern is that it is perhaps a line that runs to the rear HVAC. I don't want to develop a leak.
Broken heat shield maybe?
Maybe. I have wiggled and pulled on everything imaginable under there. I do see one shield that will need repair but that one is not making the noise.
One of my coworkers is going to help me find it today. I will keep Yall Posted.
