Tom Joad
French V8 lover.
Chamonix-Mont Blanc ski resort,. France
ks03
Fool Excess Member
Thx Chris, I'll check it out tomorrow. Probably give it away anyway. How would this cam perform in a 4.8 or 5.3? Just curious.
screenshot of a Richard holdener video, I don’t remember the engine/ setup, but cam is the only difference between runs. Guessing this is on a 5.3
Sam Harris
I know. I've done this years ago and ezven created a thread about it here.
The issue was I lost the Cruise Control and it is very useful to me so I'd rather have incandescent bulbs at the back AND CC ranther than just LED bulbs. ^^
Well, with this, my cruise works just fine. That’s what I was trying to say.
05Single
afraid of the dark
The window trim. Specifically the rear windows. And tailgate / hatch window trim. (I would like to replace the rear with a trim-free version ASAP, but for now I have the trimmed glass.
Also, tbh, I’m using either the Chemical Guys VHT, or the Chemical Guys TVD tire and trim gel.
It seems like it doesn’t really soak in, or change the trim at all. It’s just a layer over the top that’s pretty easily wiped off.
Other than painting the trim I’m not sure what would work better. I just want it black, to match the windows and Esky appliqués! [emoji16][emoji106]
I assumed you meant those. I use polish on those parts , they’re like a super hard rubber that’s not porous but holds onto wax really well and shine up so good they almost blend with the glass.
Yellow I use rubber dressing, blue I use polish and wax. Just try it out. No taping required. While everyone tapes these areas off I don’t when I polish/wax the truck. I swear by it and so far they’ve stayed glossy and great shape, no cracking or fading.
Dantheman1540
Sugar Loaf Mountain
I love his videos and nice find that's an awesome comparison. In a 4.8 I bet the power gains would be even a little more drastic.
Dantheman1540
Sugar Loaf Mountain
Well, I thought my fuel pump just died as the truck started to run rough at a light on my way to work then as I accelerated it died and will not start. Towed it to a buddies business nearby and checked fuel pressure at the rail. It has pressure! When pressing the valve on the fuel rain and turning the engine over fuel sprays out like a fire hose so I don't think that's the issue. My next thought is the Crank sensor? Had 60psi of oil pressure and the motor never sounded bad so I don't think anything is hurt. It almost wants to start when cranking but never does fire off. I got a bad out of the box crank sensor when I built the 6.0 in my Silverado and it took me forever to realize that's why it didn't start.
What do you guys think?
Edit: New info
Tachometer, IAT, ECT, and MAP are all readying correctly.
Timing is showing 10* steady during cranking (Not sure what startup timing is supposed to be)
The exhaust smells of gas but the engine sounds like timing is off.
Still no codes
I'm thinking Cam sensor
Sam Harris
Nice! Thanks man, I’ll try that out!
Edit: New info
Still no codes
if fuel and air are ok then it must be spark.
Dantheman1540
Sugar Loaf Mountain
Didn’t you just pull a wire? You lean on something?
I did and I looked all around that area pretty well and didn't see anything unplugged or burned. I'll look better on lunch but theres not much on that side that I can think of that I could have bumped.
I would check the coil harness
That's a good one to check, where do they typically fail at?
not sure, there have been cases where the ground breaks on the coil harness, the fix if this happens is to make a new ground or replace the harness. but I would get a meter out and check just to rule it in or out. assuming you don't have a million miles on the plugs and wires then you don't have to worry about those if the coils have power then I would move on to the injectors. just a process of elimination
The CG Tire & Trim Gel works good for me but if the plastic is too faded you’ll have to paint it.
Finished the brake project tonight. All new rears, NNBS fronts. New AC Delco performance calipers painted with POR15, R1 concepts rotors/pads, goodridge lines.
I used the Goodridge rubber clamps to route the lines. I also cut the factory ones (and hit them with high heat black, wth), so i could retain the spot to clip the wheel speed sensor cable.
Also touched up the red on the tires. With the calipers, center caps, and tires, I figure I'm around +10hp per corner now. Will get some daylight shots and do the bedding tomorrow...
Nice work Nate!:)
I really hope not. I reminded him he's had it for 4 months, and it's actually been 1 year since it's been undriveable. I didn't want to be put on the back burner--AGAIN. He said he wants to get rid of it as much as I want it back. So I let him know where I was coming from.
I was wondering when you said you hope to be driving it in the next 2 months!
briannorris
