Water in back
dreww2001
STL
I’ve been smelling the water leak for about a month finally figured out where it was coming from. It’s near the rear hvac vent. Do you think it’s hvac related or a seal?
C8D491B4-DD0F-4FF0-87D6-17DF46CE9AF3.jpeg E399E8AC-D056-4503-94BB-326F490C5AAD.jpeg
dreww2001
dreww2001
STL
Condensation dripping off rear evaporator and drain is clogged?
I tried taking the rear interior apart but the black round tab for the cargo net were really stuck I thought they’re supposed to twist off but I couldn’t get either off. Any suggestions? I feel like it’s something as simple as that. It soaked past the foam in the carpet so I’m hoping it hasn’t been going on long enough to cause the floor to rust.
HELLAbeefy
south louisana
Go under the rear passage corner of the truck there should be a small black rubber nub sticking out from body. Might take a little while to find, get some pipe cleaners or a screw driver, stick it in the nub make sure you hold your mouth wide open try to catch all the strange color liquid in your mouth. If any green or black lumps come out of the nub just chew them. Wet floor problem should be solved.
Durobans
