5202 LED bulbs
r6acer
So i just finished installing an HID kit in fog and headlights and after about 30 min of use i noticed the fogs have a slightly started to burn around the bulb when using an H16 bulb. as much as i dont want to forfeit on HID in the fog lights, i dont want to replace the lenses soon as this seems to be a common problem now that i researched. anyway,... heres an asthetic alternative some of you might be interested in...
LEDs for the fogs....
http://www.automotivelightstore.com/5202special.aspx
DwDrummer
AL
I had them and they suck IMHO. They would not lock into place and the tabs ended up breaking off. They don't put out any light and for me they didn't match my 6000K HID's. Just buy a 5202 HID kit and be done.
r6acer
r6acer
I do have the 5202 kit. the housing just isnt made to take the heat imo. Im running 5 k low beams which should match so im just going to use the LEDs until i can find a better housing.
2 E L O
Omaha, NE
Lots of people have no issues with 35W 5202 HIDs in their fogs.... :shrug: Bummer, man. But LED fogs aren't very effective. You're better off just sticking with the OEM lamps.
Conor
"Bob's your Uncle"
Seattle, WA
I am now in the process of replacing both fog light housings because one has completely melted and the other is burned yellow inside the housing. Melted to the point of it almost catching on fire. Part if it had to do with not being seated in correctly, but I am seriously considering going LED. I believe Modded is running LED fogs and said they were good, but you have them there for looks only as they don’t put out shit for light.
My fog light is so melted that the bulb itself melted all the plastic around the light and the whole back of the housing collapsed.
2 E L O
Omaha, NE
If you put a standard lamp in the housing incorrectly it would probably damage it, as well. Not the HID's fault. I don't know why people keep blaming the HIDs themselves for melted housings. A 35W HID bulb runs cooler than the OEM halogens....FACT.
Conor
"Bob's your Uncle"
Seattle, WA
is that a FACT 2elo. Then why the **** did the other side burn the housing yellow. And I am not the only one who has discussed this happening. There is no way an HID burns cooler than a halogen, otherwise that would not have happened.
FYI both fog lights were 5202 and 35 watt.
2 E L O
Omaha, NE
It is a fact, actually.... Bummer that happened to you, but the bulb itself wasn't the problem. Maybe it didn't fit right or something else. But yes, HIDs do in FACT burn cooler than halogens, all other variables ruled out. :Handshake:
Conor
"Bob's your Uncle"
Seattle, WA
Im am going to try it again. Luckily the bulbs are cheap and new fog lights are not too expensive. I am hoping that if I install the bulbs into the housings before the housings are installed that I can rule out any fitment error. I guess that will be the true test.
I have heard that the 35 watt HIDs are cooler, and by no means am I saying you are wrong. Or at least I didnt meant oo. But it sure seems like they would be. They even seemed hot to the touch, but then again maybe my halogens did too and I never noticed.
Modded
That Guy
Let me bring some Modded knowledge to thsi thread! :D
1. 35w HIDs do burn cooler than halogen bulbs.
2. Here is the twist, the stock 5202 bulbs ARE NOT halogen bulbs, they are 100% incandescent bulbs, meaning they are pretty much like your turn signal and/or taillight bulbs.
3. I know the above statement because all halogen bulbs have gas in them, the stock 5202 ones don't. I ran the Putco H16 bulbs in my fogs, which are halogen, and they used to get hot as hell and even put some heat warp on the interior of the housings. Worst part is they are small ass halogens!:Boo:
4. HIDs in these fogs cause BS too much, seated right or wrong, its just kinf of hard for the housings to handle the heat, especially when the car is not moving, but the fogs are on..
5. I run LEDs in the fogs and will never change that, they light ouput is useless pretty much, but they are bright. My HID headlights provide enough lighting for me, more than two times the light output the stock halogen lowbeams and crap stock 5202 bulbs provide COMBINED!!
Now Conor you could give HIDs a try again, but I suggest getting 20W ballast so they burn cooler (less light output though), some vendor on GMFS sells them if I remember right.
Conor
"Bob's your Uncle"
Seattle, WA
Thats a good idea. I might try that, but would the colors match? As stupid as it sounds, the most important thing to me is that the low and fogs match. I really couldnt care less about how much light is put out by the fogs, I just need them to match up to my head lights. I was also thinking about going to an LED bulb, but not sure how the colors would match.
Modded
That Guy
I say get the LEDs, the should match if you have 8k lows, and with 6k they will be slightly bluer bot not that much noticeable.
I have 9006 LED bulbs modded to fit in the fog housings, not 5202 LED bulbs, the 5202 ones are unnecessarily expensive.
Here is a pic with my 6000k low beams and LED fogs.
r6acer
r6acer
thanks modded,... i see you have the dual led for turn signals,. i was debating those,.. really wanted a visual. looks good.
Fast55
Ventura County USA
Wattage is a measure of power. The heat a bulb produces is directly proportional to the wattage. The stock bulbs are 27 watts. Therefore, a 35 watt bulb of any type is going to produce more heat than a 27 watt bulb, no way around it. That works out to over 20% more power (heat) than a stock bulb. That is why the housings melt. Those that have gotten away with it are probably not using them constantly, or are using them in very cool ambient temperatures, or both. I have been running the "Ion Spark White" Putco's for months with no issues because they are also 27 watts. Plenty of people with the correct 5202 (H16) HID kit in the fogs have had melt downs. It's not because they are stupid and didn't install them right.
Conor
"Bob's your Uncle"
Seattle, WA
Quick question for you Modded. since I am running 35 watt 600-K lows, do you think it would match the LEDs like your 55 watt 8000ks
tool2269
SA, TX
vleds just announced a 5202 bulb in about 3-4 weeks. check their facbook page.
Modded
That Guy
Oh no it won't match correctly, I have 35W 6000k HIDs just like you.
I say you order a extra set of 8000k bulbs, then run them in comparison with the 6000ks you have already, and then whichever one matches you can choose that one.
Im pretty sure 8000k 55W HIDs would be a perfect match because of color wash, I will go that route if mine ever mess up.
tx07tahoe
Houston,Tx
Those that have gotten away with it are probably not using them constantly, or are using them in very cool ambient temperatures, or both. QUOTE]
I've used my 6k's almost everyday and night for the past year with no problems.
Hodmjstone
